Help with psw-1000 subwoofer
pandemonium2k7
pandemonium2k7 Posts: 9
Hi i just acquired a used psw1000 sub woofer and i hooked it up to my onkyo HT-S580 5.1 surround receiver and the sub works great, but when i turn off the receiver the sub woofer starts to hum . When amp is turned on its fine no hum.
There are a few different ways to hook it up it seems maybe i am not hooked up right? Any help would be great thanks.
Gary
Post edited by pandemonium2k7 on
  • Montoya
    Montoya Posts: 506
    edited January 2010
    First question how is it currently hooked?
  • pandemonium2k7
    edited January 2010
    its hooked into the high level input b, it has high level inputs, high level outputs and rca jacks that's say low level input. the one i am connected is the type where you push the button and insert the wires in. i don't understand why there is a left and right input?
  • pandemonium2k7
    edited January 2010
    This is an older psw1000 by the way and the manual isn't for the one i have.
    treitz3 Posts: 20,118
    edited January 2010
    I don't understand why there is a left and right input?
    It is set up that way so both the R channel and L channel signals are amplified through the sub. You want to have both channels going into the sub, otherwise you are missing half the bass.
    Try flipping the plug around at the AC outlet the other way to see if that affects the hum.
  • pandemonium2k7
    edited January 2010
    treitz3 wrote: »
    the cord is polarized so you cant flip it around, and the onkyo only has one two wire output for subwoofer like one speaker wire, you understand?
    edited January 2010
    http://www.us.onkyo.com/hookup_detail.cfm?m=HT-S580&option=speaker&id=1401
    This is what I found for your AVR. I'm guessing that the signal for L & R are combined in the one, but....... What I would suggest is that you contact Polk customer service as well as Onkyo's CS during normal business hours to find out what option is best for your particular application.
    Good luck and keep us in the loop, please.
    Tony M Posts: 11,727
    edited January 2010
    How about the thee prong plug adapter fix? would that help in this case?
  • pandemonium2k7
    edited January 2010
    treitz3 wrote: »
    wow duh i just realized the model number of the amp is ht-r330 lol
    here is a pic of the back of amp http://www.eu.onkyo.com/products/product_en_289278.html
  • pandemonium2k7
    edited January 2010
    edited January 2010
    Well then, just get a "Y" adapter. Plug the RCA cable into the subwoofer out on the AVR, place the "y" adapter at the other end of the RCA and install the 2 ends of the "Y" adapter into the sub's R & L line level input.
  • pandemonium2k7
    edited January 2010
    will do that, thanks
    edited January 2010
    No problem. Enjoy the music and if you have any other questions, feel free to ask.
    Oh, my manners. I see that you are a new member here, missed that last night somehow. Welcome to Club Polk.
  • pandemonium2k7
    edited February 2010
    Well it didn't work when i used an rca cable hmmm
    Check your settings on the Onkyo. The sub has to receive and sense a signal in order to amplify it. If you would like to check first to make sure that the sub is not part of the issue, hook it directly up to the speaker wires. Either channel or both channels will do.
  • pandemonium2k7
    yes i have it hooked up with the speaker wires and it works great, just hums when you turn receiver off, i just unplug it when not in use right now.
    Does it still happen when the sub is set to "auto"? [as opposed to off or on]
