denon 1803 warm
glemay
I got my denon 1803 hooked up to my rti70, a paradigm cc-170, a pair of paradigm micro with a sound dynamics 12 inch sub and after about 30 minutes of playing it gets fairly warm. is this normal?
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
That's normal especially for home theater. Is your SD subwoofer powered or passive? Passive subs will make receivers run hotter.
Maurice -
having your speakers set to large will also make it run warmer.Graham
organ,
my sub is powered and only my mains are set to large, the center and surrounds are set to small.Main System:
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a -
You're fine there. If it starts to get hot, then you have a problem.
Maurice -
maurice,
thanks for the input. it only gets warm but not hot hotMain System:
Second System:
