denon 1803 warm
glemay
glemay Posts: 574
edited October 2003 in Electronics
I got my denon 1803 hooked up to my rti70, a paradigm cc-170, a pair of paradigm micro with a sound dynamics 12 inch sub and after about 30 minutes of playing it gets fairly warm. is this normal?
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Post edited by glemay on
  • organ
    organ Posts: 4,969
    edited October 2003
    That's normal especially for home theater. Is your SD subwoofer powered or passive? Passive subs will make receivers run hotter.
    Maurice
  • gatemplin
    gatemplin Posts: 1,595
    edited October 2003
    having your speakers set to large will also make it run warmer.
    Graham
  • glemay
    glemay Posts: 574
    edited October 2003
    organ,
    my sub is powered and only my mains are set to large, the center and surrounds are set to small.
    Main System:
    Second System:
  • organ
    organ Posts: 4,969
    edited October 2003
    You're fine there. If it starts to get hot, then you have a problem.
    Maurice
  • glemay
    glemay Posts: 574
    edited October 2003
    maurice,
    thanks for the input. it only gets warm but not hot hot
    Main System:
    Second System:
