Tube mod for my amp...
pearsall001
pearsall001 Posts: 5,284
edited January 2010 in Electronics
As a little winter project Stephen of Quest For Sound suggested that I let him mod my Nikko Alpha VI amp. We break each others balls all the time about those little glass thingys that glow in the dark. He just laughs because he knows I'm a big SS fan. But Stephen is a dyed in the wool tube head to say the least. Stephen has his own line of products called SQ Products (Sound Quest) that he designed & has manufactured. His latest creations are horn speakers that are downright spooky good. In fact his phone's been ringing off the hook from reviewers trying to get a pair. http://sq-products.com/ All of Stephens designs (amps, integrated amps, CD player) get glowing reviews. If anyone can do a tube mod...it's Stephen!!!
He would have to take a look at the schematics to see what could be done. He said that the mod would be on the output stage & probably would call for 6DJ8 or 12AU7 tubes. Just for **** & giggles I might just go for it.
Post edited by pearsall001 on
    tonyb Posts: 33,072
    edited January 2010
    Hell, go for it. Tubes add so much, I can barely listen anymore without something with a tube in the chain.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited January 2010
    You know everybody is going to tell you to do this Phil....and we all know what the result will be. Waste of bandwidth I say.:D
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
    heiney9 Posts: 25,432
    edited January 2010
    Tubes add Soul
  • pearsall001
    edited January 2010
    tonyb wrote: »
    We shall see...I'm still pondering!
    Mike
    I never was frugal so a little bit of waste is right up my alley!
    heiney9 wrote: »
    Tubes add Soul
    That's what I've been told! Decisions, decisions!!! :)
  • pearsall001
    edited January 2010
    Where's all the tube head opinions!! I figured you'd be breaking them by now. :D
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2010
    Do It! Do It! Do It!
    Give me a T ... Give me a U ...
    . . . a little cheer leading to get you off of your butt :D
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Phil,
    It seems to me that Steven would just be adding the tubes like a tube buffer, no? Are these going to be output power tubes?
    If indeed they are just adding tubes as like a tube buffer, I would say don't modify the amp as it will reduce the resale value and you could just buy a tube buffer and place it between the NAD and the NIKKO.
    If they are going to be power out tubes then I would say go for it even though it will still probably affect the bottom line in resale value.
    BTW you've had tubes in your rig with the CJ pre you had.
  • Face
    Face Posts: 14,340
    edited January 2010
    The Nikko fan club will have a heart attack!
    All 5 members. :D
    edited January 2010
    Phil,
    Very similar like a Jolida or any other hybrid amp where the driver stage is tubes and the output (power stage) is still transistors. Can't use 6DJ8's for power tubes
  • hearingimpared
    edited January 2010
    Face wrote: »
    All 5 members. :D
    Hehehe!
  • hearingimpared
    edited January 2010
    heiney9 wrote: »
    I didn't think so.
    edited January 2010
    But it does remain to be seen if it will be just a "buffer" between the input and output stage still using the SS drivers or if it will be a "true tube driver" stage getting rid of the SS drivers.
  • hearingimpared
    edited January 2010
    heiney9 wrote: »
    From the conversations I had with Phil about it, I didn't think Stephen was going to go that deep.
  • madmax
    madmax Posts: 12,434
    edited January 2010
    If its a tube buffer I wouldn't do it. Maybe he can replace the output stage with tubes too, now that would be worth it. :)
    madmax
    Vinyl, the final frontier...
  • pearsall001
    edited January 2010
    I'll have to get better clarification from Stephen on exactly what he has in mind. From our conversation there was never any discussion of merely being a tube buffer mod. He did say tube output stage.
    As far as resale value goes I know it will effect it but that's not a real concern. I pretty much plan on keeping it for the long haul. It's just so purdy!!!!
    The Nikko club (all 5 of us :D) will get over it.
  • hearingimpared
    edited January 2010
    I'm very interested to hear what Stephen has in mind Phil. Keep me in the loop please.
    mhardy6647 Posts: 35,005
    edited January 2010
    Face wrote: »
    All 5 members. :D
    They actually made some pretty nice tuners... and Charles King has modified 'em with vaccum tube output stages to good effect (I believe the one I heard was a Gamma 3, but I could be wrong about that).
  • pearsall001
    edited January 2010
    Joe, here's the skinny...no, it is not a tube buffer mod. The SS power will remain the same, Stephen is adding a true tube output stage after that with either 6DJ8 or 12AU7 tubes. His remarks are that this mod will sweeten up the midrange & give it more air. This all hinges on space inside the unit, once he opens it up he'll see if there's even room to do all this. That still remains to be seen.
    edited January 2010
    So it's a driver stage.....meaning the tubes will "drive" the current SS output. The confusion comes from saying it's in the output stage. It's not the final output, but the driver stage (which takes the input signal from a source and outputs the signal to the output (power) stage).
    Glad to hear it's a true driver stage and not just a buffer.
  • Face
    Face Posts: 14,340
    edited January 2010
    If it hasn't been done already, have him update all the caps in the signal path while he's in there, passive components have come a long way since. I recently updated all the caps in my McIntosh MC-7270 with Nichicon FG series caps and it was a nice improvement.
    edited January 2010
    Nichicon FG caps are very nice and easy on the wallet.
    +1 on that recommendation
  • pearsall001
    edited January 2010
    heiney9 wrote: »
    That's it!!! My apologies for using the wrong terminology. Hell, I'm still confused.
    Face wrote: »
    16 of them can't be that inexpensive. I don't know if I want to get that involved. This is just being done more for the fun of it just to give me another taste of tubes in the chain. You never know though.
    edited January 2010
    Either way even if you end up not doing the tube stage..............it is definitely at that age where a re-cap should be done. No, with labor to have someone else do it it's not going to be cheap the caps aren't that expensive. I'd still recommend it even if you decide not to do the tubes.
    The thing with caps is they degrade so gradually (unless they really go out) that one hardly notices until they compare the old vs. the new. So while it might sound great now............with new caps it will sound even better.
    Just something to think about
  • pearsall001
    edited January 2010
    Thanks, I'll definitely bring up the caps issue with Stephen to see what he recommends. Damn, I have to watch the wallet on how this is progressing.
  • hearingimpared
    edited January 2010
    Good luck prying that dried prune open!:D
  • pearsall001
    edited January 2010
    Cobwebs bro cobwebs!!! :D Or I'll just put it on your account. :eek:
  • hearingimpared
    edited January 2010
    You will end up getting phone calls from collection agencies!:eek:
