FXi30 placement
brianwayne671
brianwayne671 Posts: 41
edited October 2003 in Speakers
O.K. weird question here. I have my FXi30's placed on the wall directly behind my sofa in bi-pole mode. The question is this: on the back of the speakers they are labeled R and L for the right and left channels. However, if you place them in those locations the drivers 5 1/4's are facing away from the listening area and the tweeter's are facing toward's the listening area. Now I have mine setup OPPOSITE of this because it didn't make sense to me. My drivers are facing in towards the listener. I just don't feel I'm getting terrific surround out of these babies and wondered if it could be something else I did. Did I do it correctly? Can anyone let me know how they have theirs? Thanks.
Bri
Post edited by brianwayne671 on
  • Airplay355
    Airplay355 Posts: 4,298
    edited October 2003
    i have mine on the back wall above my space for a couch(couch not there yet) in bipole mode. i have the left on the left and the right on the right making the mid drivers face the outer walls...i like the way it sounds. i havent tried dipole on the sided or bipole on the sided yet tho.
  • brianwayne671
    edited October 2003
    So, is that the way they are setup to be placed? Do I have them setup incorrectly?
    Bri
  • DonCB
    DonCB Posts: 24
    edited October 2003
    I run my FXi30s the same way... They are on the wall behind me... I have the woofers pointed at me ... it seemed silly to have the woofers pointed away, especially when they are run in bi-pole.
    Don
  • thehalo8
    thehalo8 Posts: 127
    edited October 2003
    I have mine on the back wall where my couch is too. Mine are set with the woofers going to the walls rather than the middle. They are set to Bi-pole and this is the only set up I have ever tried. They sound good to me, maybe I will play with them this weekend and switch them around.
    Mike
    Mains: Polk RTi70's
    Center: Polk CSi40
    Surrounds: Polk TC60i's
    Sub: Polk PSW505
    Receiver: Onkyo TX-DS696
    TV: Samsung HLS 5687W 56"
    DVD: Sony DVP S5300
    Protection: Monster HTS 3600
    Backup Battery: Belkin AP3080010
  • DonCB
    DonCB Posts: 24
    edited October 2003
    Well if you had them on the side walls a little behind you the woofers would be aimed at you.....
    Don
  • brianwayne671
    edited October 2003
    D*mn, this sure is confusing eh? :confused:
  • jkratzer
    jkratzer Posts: 148
    edited October 2003
    I emailed Polk on this and here is their response:
    Hello James,
    Most folks prefer, and we agree, the best way to mount the f/xi series is to have the side with the larger mid range driver facing into the listening area. So to answer your question, yes, you will want to reverse the speakers, the bi-pole setting is correct.
    Sincerely,
    Lauren
    Polk Audio
    My 7.1 setup consists of:
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RTi28s side surround
    FXi30s back surround
    PSW202 Subwoofer - Hey, it's my first sub!
    RCA 46" 4:3 RPTV
  • Airplay355
    edited October 2003
    im switching them right now lol....thanks for the info
  • brianwayne671
    edited October 2003
    Hey Airplay, I'm curious. How do they sound now compared to before? Hey Kratz, looks like we're neighbors!
    Bri
  • eclypse
    eclypse Posts: 595
    edited October 2003
    Hello James,
    Sincerely,
    Lauren
    Polk Audio
    Thats the way they explain it in the manual.. the right way.
    Full 5 channel set of Polk Audio
    Fronts - LSiM 705
    Center - LSiM 706c
    Sides - LSiM 703
    Mits WD-82842 82" DLP 3DTV
    Denon AVR-3313CI Receiver
    Emotiva stealth DC-1
    Emotiva XPA-2/Fronts XPA-3 Center-surrounds
    Oppo 103
    Loving the new Family! :)
  • danger boy
    danger boy Posts: 15,722
    edited October 2003
    this is how i have mine set up from day uno.. and it sounds incredible. I have friends who come over to hear my system.. and they can't believe how good the surrounds sound. Most of them use direct forward firing speakers for surrounds.
    Mine are the older version of your's. FX/300i to be exact.
    anyhoo. i run mine in bi-pole as well. here is the difference. I have mine about 2.5 to 3ft above my listening position. except mine are placed on the side wall slightly behind me. (I couldn't mount them on the back wall. because of one big **** window).
    reason for this.. the front of it fires towards the front of the room.. and the rear tweeter fires into the back wall.. and bounces off. the surround sound effect is fantasic. Once i set them up about 3 yrs ago. they never needed any other adjustments... except a good dusting once a month.
    happy happy joy joy! ;)
    PolkFest 2012, who's going>?
  • Airplay355
    edited October 2003
    i was thinking about doing that and maybe placing a center in because my receiver is 6.1 but i already hung them up this way and honestly i think my room it too small for 6.1, especially how i have it setup with my furniture.
    well they definitely sound different with the mids facing inwards...im not sure if i like it yet. i might switch it back to see which one is more to my liking.
    the differences is that you hear more of the surround midrange sounds. im guessing they dont bounce around as well as the high sounds so they might just be lost when the mid woofers are facing outwards.
    it seems to bring alittle more attention to the surrounds but i think thats where im sitting more then anything, i dont have my couch in yet so to be in the middle of my system i have to sit on a chest direcrtly under my speakers...the couch will be alitle farther into the room and as soon as i move to the middle of the room it sounds better.
    if you wanna really listen to your surrounds watch a movie like signs, or the part in the lion king where simba burps when hes with timone and pumba.
    good luck with your speakers
  • donahue
    donahue Posts: 125
    edited October 2003
    I think most people get confused by what is meant by left and right when positioning surround speakers. The speaker marked L should go to your left from the sitting position, not looking at the back wall. So if your surrounds are on the back wall, the speaker marked L should fire over your left shoulder and the speaker marked R should fire over your right shoulder. The best placement is also 2-3 feet above your listening position (seated).
    My 2 cents
  • brianwayne671
    edited October 2003
    Actually Donahue, they are labeled just the way you described. To have the mids facing inward you must do the opposite of that. In other words, the R speaker firing over your left shoulder and the L speaker firing over your right. That's the reason for all the confusion.
    Bri
  • Airplay355
    edited October 2003
    we are in a polk forum, we are always confused about something lol :p
  • scottvamp
    scottvamp Posts: 3,277
    edited October 2003
    1)Most of you guys have a 5 channel set up.
    2)In a 5 channel set up when using a di-pole type speaker they are supposed to be at the SIDES of you NOT in the back.
    3)According to polk in the side configuration the driver should be facing forward. This will "bounce" the sound on to the front stage and back to the listener. I have read a more detailed reason but can't remember right now. A two sided di-pole (especially one with a driver only on one side) is not going to sound anything like a direct radiating speaker. It is suppose to create a spacious ambient sound field (rain , crikets chirping, birds). With a 6/7 channel setup you get the best of both worlds using direct in the rear and di-pole on the sides.
    However what ever sounds best to you is what YOUR HT is all about.
    I have a typical 7 channel setup with fx500 (di-pole) at the sides of the theater and rt35's in the rear.
    Hope this helps the confusion.
  • jkratzer
    jkratzer Posts: 148
    edited October 2003
    Bri
    Agreed. I have the speaker labeled "R" firing over my left shoulder and the speaker labeled "L" firing over my right shoulder. This causes the midwoofer to be facing the audience with the speakers behind me in bipole mode.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • donahue
    donahue Posts: 125
    edited October 2003
    This is not the way that Polk recommends placing these speakers, based on the manual. Here is what the manual states for the FXi30/50:
    One FXi speaker is the “left” channel speaker, and
    the other is the “right” channel speaker. The serial number label identifies which speaker is
    which [figure 2]. The “left” surround speaker should be placed on the left side of the room as you
    face the front of the room. The type of surround processor you use will influence your placement
    and bi-pole/di-pole switching choices
    Does this only apply if the speakers are to the sides? My couch is only about 3 inches from the back wall. What would be the best placement for this setup (it's 5.1 only) ? I do not have the ability to put the speakers to the side. Which setting would be best, bipole or dipole? In this setup, should the left speaker go on the right and vice-versa?
  • scottvamp
    edited October 2003
    That is correct left speaker left side and the driver will face forward or outside in the rear. In the rear the driver sound will bounce of the side wall and back into the middle of the room depending on how close to the wall the speaker is. This once again creates a DIFFUSED sound. The way a surround speaker is supose to sound in a home theater. Some people like a more direct sound (reason being is it just simply seems LOUDER).
    Once again it is all about personal preference.
    Direct (bi-pole) is much more perferred for muti channel music listening. Therefor Polk gives you a switch to chose either or.
  • jkratzer
    jkratzer Posts: 148
    edited October 2003
    Bipole also works better on the back wall if the seating position is almost against the back wall to provide a more diffuse sound. Direct radiators don't have an opportunity to speard the sound out well enough in this situation. This is my situation.
    Denon 3803
    Panasonic DVD
    RTi70s front
    CSi40 front center
    RCA 46" 4:3 RPTV
  • brianwayne671
    edited October 2003
    Hey Airplay, you seem to have tried both methods. Which did you prefer?
    Bri
  • thehalo8
    thehalo8 Posts: 127
    edited October 2003
    My couch is also only a few inches from the wall, and I have the FXs on the back wall behind me in Bi-pole. In my last place my couch was more in the middle of the room, and the FXs were further apart (they sounded awesome). But now I own a home and have to make sacrifices to my HT for my wife’s sake. Even though they are much closer together, they still sound good.
    Before I installed the FXs I used ladders and books to put them at different height levels till I found the height that sounded the best. Then I put my wires up through the wall, through the attic, and down inside the wall and out where the speakers were to be place (that was a ****!!). Conveniently as it turned out the best sounding location for my speakers, the top of the speakers are level with the window which added a nice touch. I will switch my speakers this weekend to the woofers facing in, and give my feedback next week.
    Mains: Polk RTi70's
    Center: Polk CSi40
    Sub: Polk PSW505
    DVD: Sony DVP S5300
