Mortite for ported speaker?
iskandam
iskandam Posts: 704
edited January 2010 in DIY, Mods & Tweaks
Will using mortite to seal drivers in a ported design be as beneficial as sealed speakers?
Post edited by iskandam on
  • Conradicles
    Conradicles Posts: 6,364
    edited January 2010
    No. Think about it for a little bit.
  • iskandam
    iskandam Posts: 704
    edited January 2010
    That's what prompted the question in the first place :D
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    I don't think it's a bad idea to firmly seal your drivers and allow the port and loudspeaker to work at peak efficiency. It's also not expensive, so a no-brainer for me. Vintage speakers are usually not examples of tight tolerances and aerospace level engineering.
  • Paden501
    Paden501 Posts: 286
    edited January 2010
    It should help. Logic says that a tight seal would mean less air escaping around the drivers and more air flowing through the port, which is good because the port is designed for a certain frequency based on its length and volume... air leakage around the driver is not.
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
  • zingo
    zingo Posts: 11,258
    edited January 2010
    Paden501 wrote: »
    Bingo. But as correctly stated before, it will not make as much of a difference as a sealed design speaker.
    What speaker are you wanting to Mortite?
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    The Mortite does more than just seal your speakers. The basket is tied to the cabinet better and prevents any ringing.
    Ben
    Ben
  • iskandam
    iskandam Posts: 704
    edited January 2010
    zingo wrote: »
    Built from scratch. My first DIY project. The alternative is this
  • iskandam
    iskandam Posts: 704
    edited January 2010
    This is something that you use on all the drivers, not just the woofers, right?
    I will be flushmounting all of them on the front baffle. Do I need to make the countersink holes a bit deeper or will the mortite compress down to nothing?
  • zingo
    zingo Posts: 11,258
    edited January 2010
    Correct. You should be sealing anything that screws onto the cabinet: woofers, tweeters, binding post cups.
  • dorokusai
    edited January 2010
    iskandam wrote: »
    You don't have to caulk it up like a bathroom and there's no need for cabinet modification.
  • kcoc321
    kcoc321 Posts: 1,788
    edited January 2010
    I use my finger to flatten it out as much as possible, and then tighten the screws like you do when tightening down a tire, alternating across, maintaining the same degree of tightening on all the screws. Someone else said to come back in a few days and check them again, but mine did not require any additional tightening.
  • iskandam
    iskandam Posts: 704
    edited January 2010
    excellent, thanks for all the helpful information!
