Mortite for ported speaker?
iskandam
Will using mortite to seal drivers in a ported design be as beneficial as sealed speakers?
No. Think about it for a little bit.
That's what prompted the question in the first place
I don't think it's a bad idea to firmly seal your drivers and allow the port and loudspeaker to work at peak efficiency. It's also not expensive, so a no-brainer for me. Vintage speakers are usually not examples of tight tolerances and aerospace level engineering.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
It should help. Logic says that a tight seal would mean less air escaping around the drivers and more air flowing through the port, which is good because the port is designed for a certain frequency based on its length and volume... air leakage around the driver is not.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
Bingo. But as correctly stated before, it will not make as much of a difference as a sealed design speaker.
What speaker are you wanting to Mortite? -
The Mortite does more than just seal your speakers. The basket is tied to the cabinet better and prevents any ringing.
Ben -
Built from scratch. My first DIY project. The alternative is thisBingo. But as correctly stated before, it will not make as much of a difference as a sealed design speaker.
This is something that you use on all the drivers, not just the woofers, right?
I will be flushmounting all of them on the front baffle. Do I need to make the countersink holes a bit deeper or will the mortite compress down to nothing? -
Correct. You should be sealing anything that screws onto the cabinet: woofers, tweeters, binding post cups.
You don't have to caulk it up like a bathroom and there's no need for cabinet modification.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I use my finger to flatten it out as much as possible, and then tighten the screws like you do when tightening down a tire, alternating across, maintaining the same degree of tightening on all the screws. Someone else said to come back in a few days and check them again, but mine did not require any additional tightening.
excellent, thanks for all the helpful information!
