Good amp for LSi9 2 channel
OK. You guys have me blowing my budget. But oh well. Now I am reading about an integrated Krell S 300i. $2500. Here are the specs. I am not even sure which specs are important! Would that be a good match for my LSI9's? If I got that, I would s-can my Onkyo AVR I am using for a pre out. Thoughts on that?
Specifications:
Frequency Response: 20 Hz–20 kHz (+0 Db, -0.14 dB)
Signal/Noise Ratio: “A” Weighted 90 dB
THD: @ 1kHz <0.04% / @ 20 kHz <0.25%
Gain: 32.5 dB
Input Sensitivity: 0.82 VRMS
Input Impedance:
47 kOhms Single-Ended
94 kOhms Balanced
Output Impedance: 0.15 Ohms
Power Consumption:
Idle 20 W
Max. 1,800 W
Transformer: 750VA
Inputs: All with Theater Throughput
1 Pair Balanced via XLR Connectors
3 Pair Single-Ended via RCA Connectors
1 Ipod via 30-Pin Connector
Outputs:
Loudspeaker via 5-Standard Binding Posts (Pr)
Single-Ended Preamp via RCA Connectors (Pr)
Output Voltage:
Peak To Peak 138 V
Output Power:
8 Ohms @ 150 W
4 Ohms @ 300 W
Remote Control
Handheld Wireless Remote
12 VDC Trigger Ouput
12 VDC Trigger Input
RC-5 Input via 1/8” Stereo Connector
Dimensions (HWD): 4x17.25x17.5"
Weight:
Shipped: 51.0 lbs Unit Only: 43.0 lbs -
You could keep the Onkyo for HT and the integrated for music listening for the best of both worlds."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
