sda ques
mcintosh12
mcintosh12 Posts: 4
edited January 2010 in Speakers
i have a pair of 2b sda's im using a rca monster patch cord in the round sda hole it is working am i getting the full effect like this it sounds better to me without the cable plugged in could it be placement maybe any thoughts?
Post edited by mcintosh12 on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Typical placement as recommeded by Polk is; Three feet from the side walls, no less then 4' apart with 6 to 8' apart being ideal, and as far from the back wall as needed for proper bass response.
    Welcome again. As I posted in your other thread, IMHO you'd be better off seeking out a proper SDA cable. It will be safer and probably sound better.
    F1nut Posts: 52,005
    edited January 2010
    They must be parallel to the back wall, no toe in.
  • hearingimpared
    edited January 2010
    Oh yeah I forgot. However, if you use them WITHOUT the SDA cable some toe may be necessary.
    edited January 2010
    Whats the point in getting SDA's then ? Would someone actually get SDA's and not use the cable ? If so, I have to question their sanity.
  • hearingimpared
    edited January 2010
    tonyb wrote: »
    I don't think anyone would buy SDAs and not use the SDA cable. The problem is a lot are sold without the cable and it brings up these types of questions. How you would loose the SDA cable is beyond me. I think some of these sellers have the SDAs in storage for long periods of time and forget about the SDA cable.
  • mcintosh12
    mcintosh12 Posts: 4
    edited January 2010
    thanks guys for the info i decided to trade up and got a pair of srs 3.1 much much better sounding to me than the 2b's
    edited January 2010
    What size room are you running the SRSs in?
    cnh
  • mcintosh12
    mcintosh12 Posts: 4
    edited January 2010
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    If you can set them up on the long walls it would be better.
    Ben
