SDA2RTA12cTL Hybrid?
falconcry72
falconcry72 Posts: 3,580
edited January 2010 in Vintage Speakers
I just got a pair of RTA12c's, and I was taken aback by how similar they are to the SDA 2's. Same exact sized cabinets (measuring to the top of the RTA's exposed tweeter), same tweeter type, same kind, number and placement of woofers, and same placement and type of passive radiator. So here's the question: could you wire the rta12c to act as a SDA? I don't know what this would entail, but I'd imagine there would some guts from the SDA you'd have hook up into the RTA to make one of the woofers send out the stereo signal and one send out the dimensioanl signal. Then there's the matter of the interconnect cable. Is this possible? It seems to me that if this could be reasonably done you'd end up with a really cool speaker set. It would have the stereo dimensional array of the SDA while maintaing the real time array of the RTA with the recessed tweeter. Best of both worlds? Heck, you could even TL'em while your at it and make a SDA2RTA12cTL.
Is any of this possible? Sane? Thanks experts! :o
Post edited by falconcry72 on
  • TNTsTunes
    TNTsTunes Posts: 751
    edited January 2010
    Yes, anything is possible.
    You would need to rework the crossover. The drivers need a divider also. I was told once it is at a 7 degree angle. You would need to check the divider and what drivers it has. A SDA-2B crossover would be a good starting point. Rebuild it with the proper caps and resistors. I would TL it at the same time. They may take some tweaking to the crossovers to get that sound we know and love.
    Most people might not agree but done properly you should have a great set of speakers.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    heiney9 Posts: 25,406
    edited January 2010
    The drivers and the tweeters are NOT in the same placement. It's also not possible to retain the "RTA" characteristics and SDA characteristics simultaneously. The amount of re-engineering to make them into SDA's is not worth it. If you want SDA's........buy SDA's.
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2010
    Just find some 2B's and do the TL mod and you will much happier. IMHO.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    Yep.
    Ben
  • falconcry72
    edited January 2010
    heiney9 wrote: »
    It looks to me like the drivers and passive radiators are in the same placement, with the SDA2a's and b's anyway, I guess I should have clarified that to exclude the first SDA 2's. I didn't say that the tweeters were in the same placement, just that they were the same model and quantity. And please correct me if I'm wrong, but I thought the RTA effect happening on the 12c's was due to the placement of the tweeter: recessed so its voicecoil is aligned with the drivers' voice coils. If that is true, then you could have the SDA and RTA effect happen simultaneously. Now please tell me where I'm wrong. Thanks again, your noob friend, falcon.
    edited January 2010
    They aren't. The baffle on SDA's has anywhere between a 7* and 12* slant inwards on the dimensional array, probably not visible to the naked eye. I have never measured the distance between the drivers on RTA12's or M10's but if they are even off by 1/4" compared to the distance between the regular and dimensional drivers on the SDA's then the SDA properties are diminished.
    If you can find the original "white paper" published in Audio Magazine in the 80's it gives a superb overview of all that's involved including theories on SDA's and you would then see just slapping a X-over in M10's or RTA 12's won;t get it done.
    edited January 2010
    The SDA properties don't use "real time alignment" as part of the design. In multiple tweeter SDA's the tweeters are arranged in a progressive point source array. Something completely different than RTA. Not saying RTA isn't a great thing.............I don't see how you can have both in the same cabinet. Again reading the "white paper" would illuminate a lot of these things.
  • falconcry72
    edited January 2010
    H9,
    Thanks for all the insight. I think I'll just wait for some SDA's and not screw up my RTA's. :o
    So my new question, which I'm sure has been answered here but I couldn't find it, is: what's the difference between SDA 2b's and 2a's?? Thanks again,
    falcon
    edited January 2010
    Falcon, that's really the best. The RTA 12's are very nice and there just isn't an easy, cut and dried way of converting them into SDA's.
    Start looking for a pair of SDA's locally or within driving distance.
  • TNTsTunes
    edited January 2010
    H9,
    falcon
    The midbass drivers and crossovers are different.
    Check out the SDA wiring diagrams in the stickys on the top of the vintage speaker forum.
    edited January 2010
    2B's are the better choice. Better cabinets, x-overs and drivers. 2A's are nice too, but always hold out for the "newest" SDA's or later generation SDA's as they were on a constant improvement path with the last 2 generations being the best (which includes the 2B's)
  • falconcry72
    edited January 2010
    heiney9 wrote: »
    what other SDA's as are a part of the "last 2 generations"? I'm guessing all of the SRS's, maybe 1C's?
    edited January 2010
    Last generation would have been the last SDA's
    SRS 1.2TL
    SRS 2.3TL
    SRS 3.1TL
    The gen before that was
    CRS +
    2B's
    1C's
    SRS 2.3
    SRS 1.2
    To me those are the more desirable SDA's. Special mention to the SRS 2's.
