Sony preamp help needed
halo71
halo71 Posts: 4,631
edited January 2010 in Electronics
I have an older model Onkyo pre that was not a cheap model when new. I wanna use it in a garage rig. But I have noticed that it does not switch between inputs correctly sometimes. Like it hangs or switchs really slow, or doesn't switch at all. I am not talking about the knob position hanging, just won't switch from CD to tuner sometimes for example, even though the knob is moved.
Anyone have any ideas? Maybe its a cheap fix? I really don't have the cash for new/used pre. I do have a really old Pioneer receiver with preouts I guess I could use though in its place.
--Gary--
Post edited by halo71 on
  • halo71
    halo71 Posts: 4,631
    edited January 2010
    Not sure why I put Sony in the title, it's actually an Onkyo preamp. :confused:
    --Gary--
    billbillw Posts: 7,535
    edited January 2010
    Is it a remote control model or not? If it is not, then its probably dirty contacts. If its a remote model, there may be a motorized rotary switch that needs oiling and contact cleaning.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2010
    billbillw wrote: »
    +1 Agreed Dirty contacts. Deox it
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
