Sony preamp help needed
halo71
I have an older model Onkyo pre that was not a cheap model when new. I wanna use it in a garage rig. But I have noticed that it does not switch between inputs correctly sometimes. Like it hangs or switchs really slow, or doesn't switch at all. I am not talking about the knob position hanging, just won't switch from CD to tuner sometimes for example, even though the knob is moved.
Anyone have any ideas? Maybe its a cheap fix? I really don't have the cash for new/used pre. I do have a really old Pioneer receiver with preouts I guess I could use though in its place.
--Gary--
Post edited by halo71 on
Not sure why I put Sony in the title, it's actually an Onkyo preamp.
--Gary--
Is it a remote control model or not? If it is not, then its probably dirty contacts. If its a remote model, there may be a motorized rotary switch that needs oiling and contact cleaning.
+1 Agreed Dirty contacts. Deox it
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
