Carver c-4000 pre
mjg
Found a carver C-4000 pre-amp on cl for $200.00. Any body familiar with this unit? Is this a good buy. Would be used ahead of a carver TFM 24.
Thanks Maurice.
Thanks Maurice.
Post edited by mjg on
That's a very decent price for a really nice pre. I'm using a C-1 which is the little brother of the C-4000 and a TFM-25 and it sounds great. By the way I payed $275 Canadian for the C-1 about 2 years ago.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Thanks for the response. With basicly the same amp, you are just the person I wanted to hear from.
Thanks again, Maurice -
That's a decent price. I have a C-1 that I really like. As Fongolio said, they're very similar to the C-4000.
I've had mine paired with both a TFM-25 and M1.0T. Both ways it sounds very good.~Matt
My System
Front L/R: Definitive BP10Bs
Surrounds -Polk Audio Monitor 4As
Preamp: B&K Reference 20
CD: Jolida JD100a
L/R Amp: Carver TFM-24
Turntable: Pioneer PL-516 W/ Shure M97xe
TV: Sony 52" XBR9 -
Here's a short but interesting read I just found on this topic over at the carver forum.
http://www.carveraudio.com/phpBB3/viewtopic.php?f=8&t=10809~Matt
My System
CD: Jolida JD100a
TV: Sony 52" XBR9
