only tweak one thing at a time
superjunior
superjunior Posts: 1,632
edited February 2010 in DIY, Mods & Tweaks
so I installed my speaker spikes, my new set of old mit t3s (brand new but old), and replaced the binding post plates with jumpers - all at the same time. fired up the system and let the speakers open up a bit. the sound sure is different all right - freeking horrible! the slamming base is gone, the mids and highs are harsh and detail is gone. I tried playing with the eq in the avr but I know thats got nothing to do with it. SO, I'm gonna rule the speaker spikes out - thats not the problem. the speaker cables are brand new mit terminator 3 and I have mit avt3 ics. I emailed gavin at mit to ask if avt3 would match with old t3s, he replied and said he sent the question to someone else there who knew more about old cables but I haven't heard back, so I hooked em up. I'm thinking (hoping) the speaker cables just need to burn in. or they might not match well with the avt3s, I don't know. I used the 14g speaker wire that ran my mains for a pair of jumpers. this is why never to tweak more than one thing at a time, and I knew better dammit :p any thoughts?
panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one
Post edited by superjunior on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Unfortunately no more than you've already expressed. YOu are right however it is not the spikes.
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    I'd say wait to make a decision until everything is burned in. But yeah... i hear you. :)
  • superjunior
    edited January 2010
    anyone that saise cables don't matter needs to have their head examined! :D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Ern Dog
    Ern Dog Posts: 2,237
    edited January 2010
    Try putting your old speaker cables back in. If you know for sure it is the speaker cables, then you definitely need to let them break in before making any decisions.
  • superjunior
    edited January 2010
    Ern Dog wrote: »
    yeah, that would probably be the fastest way to pinpoint the issue
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • jz0h4d
    jz0h4d Posts: 33
    edited January 2010
    What in the world do you think has to "burn in" in a cable?
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    The cable. As you move up to better equipment you will realize that good cables need to burn in.
    Ben
  • jz0h4d
    jz0h4d Posts: 33
    edited January 2010
  • superjunior
    edited January 2010
    jz0h4d wrote: »
    Nonsence.
    really? please explain :rolleyes:
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Zitro
    Zitro Posts: 864
    edited January 2010
    Oh boy, here we go lol
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • Paden501
    Paden501 Posts: 286
    edited January 2010
    Time to get a Snickers. This one's not going anywhere for a while
    ~Matt
    My System
    Front L/R: Definitive BP10Bs
    Surrounds -Polk Audio Monitor 4As
    Preamp: B&K Reference 20
    CD: Jolida JD100a
    L/R Amp: Carver TFM-24
    Turntable: Pioneer PL-516 W/ Shure M97xe
    TV: Sony 52" XBR9
  • hearingimpared
    edited January 2010
    Don't worry guys we go through this every year around this time. It'll calm down and they will go away. Just don't feed into it.
  • superjunior
    edited January 2010
    your right Joe, wish I could retract my last post as to not feed the fuel for troll consumption.
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • jimmydep
    jimmydep Posts: 1,305
    edited January 2010
    Ern Dog wrote: »
    I agree with Ern dog.....start from scratch and make one change at a time.
  • concealer404
    edited January 2010
    baleeeeeeeeeeeeeeeeeeeeeeeeeted!
  • SolidSqual
    SolidSqual Posts: 5,218
    edited January 2010
    Hey Superjunior, I had the exact same experience with a full set of MIT Shotgun S3s. Break-in is definitely a factor. Just persevere and keep your old cables. If the sound doesn't exceed the performance of your old cables, just put the old ones back where they belong.
  • packetjones
    packetjones Posts: 1,059
    edited January 2010
    I just did multiple tweaks as well. I installed spikes and jumpers and could tell a difference for sure. I wish i would have done them one tweak at a time so i would know which one made the bigger difference. I would say that the new speaker cables are the culprit for the sound issues you are having. There is no way that the spikes would do it and the jumper would ave to be better than that plates that come stock. Give it some time and see if it gets better. if not you can always go back.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • superjunior
    edited January 2010
    thanks fellas. I'm gonna let these cables break in for at least a week before I do anything, I'm pretty darn sure thats the issue so I'll wait it out and see
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    Toolfan66 Posts: 18,066
    edited January 2010
    I started with brand new MIT speaker cables ,IC's, modded crossovers, RDO-198 tweeters, drivers dynamated and mortited all at one time. IMO the MIT"s take some time breaking in.
    The only tweek I did about 20 days later was put the spikes on.No complants here, I loved hearing everything open up as time went on.
  • thsmith
    thsmith Posts: 6,082
    edited January 2010
    SupperJ, I am in the camp of cables burning in as well as tubes, caps what have you.
    When I put MITs in my system they immediately sounded better than what I has already and only got better. I have found this to be true in must cases with most things, si IMO unless your new cables are a step dowen or defective cable burn in will not fix your problem.
    Since you touched the binding post and jumpers. I would double check my work for bad solder, shorts, opens or misplacement of leads. I would also go back to old jumpers.
  • superjunior
    edited January 2010
    thsmith wrote: »
    I went from reg 14g wire from best buy to the mits. I sappose I could throw on the old binding post plates and determine where the problem is that much faster. can't do it now though, got people coming over to watch football :)
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • thsmith
    edited January 2010
    When I went from AQ T4 to Mit S3 SHotguns the not yet burned in MITs sounded better immediately and only got better.
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2010
    jz0h4d wrote: »
    Nonsence.
    At least spell it correctly.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • hearingimpared
    edited January 2010
    BIZILL wrote: »
    Really, if you're going to troll atleast look like there is some intelligence involved.
  • superjunior
    edited January 2010
    over the course of this last week while watching tv and movies I've noticed my front soundstage just sounding better and better. I popped in a tool cd last night and I just couldn't beleive my ears! all I can say is wow! mids and highs are more clear and detailed than ever, base is punching me in the chest. I can't wait to hear what it sounds like in another week :D:D:D
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    heiney9 Posts: 25,436
    edited January 2010
    I just recently bought NOS pair of MIT Terminator 2 I/C's for my office rig they sounded horrible when I first hooked them up compared to my Signal Cables......after about a week or two of break-in they sound much better. My other MIT's in the main rig were used and already broken in. Let them break in and if you still don't feel they make a positive difference, MIT's hold their value so you can flip them. But give 'em a chance.
  • superjunior
    edited January 2010
    beleive me h-9, I am convinced. I'm floored by the difference after just one week
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • zingo
    zingo Posts: 11,258
    edited January 2010
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2010
    I went from Monster wires to MIT AVT3's to MIT shotgun s3's and didn't notices a big difference right away. After weeks of breaking them in the sound grew on me and I didn't notice the HUGE difference until I put my Monsters back in and it was a night and day difference.
  • superjunior
    edited January 2010
    leroyjr1 wrote: »
    since the original speaker cables were ran underneeth the carpet I still have them coiled up behind the speakers. It will be interesting to do a side by side comparison once the mits are fully broke in
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
