popping sound...
braaaaay
good day,
is it normal when i turned on my sub i hear a tiny popping sound. sub is psw110 and about 4mos old.
Post edited by braaaaay on
That popping sound may be bad news. My Psw1000 is in the shop cause the amp stopped working. The popping sound started just before it went dead.
All my power and wire connections were tight which you might want to check.Polk LSi15 mains
Polk CS400i center
Polk FXi50 rear surrounds
Polk PSW1000 sub
Pioneer Elite VSX-81TXV AVR
(2) Outlaw 2200 amps
Sony DVP-NS75H
Pioneer 50" Plasma PDP-5080HD
Monster power HTS1600 -
Another thing to check is if it makes the popping sound when it it not connected to anything else. If it is only plugged into power and no sub cable does it still make the same noise?Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
it only happens when i unplug the power cable then plugging it back in, then i hear a tiny pop sound. so what i did was not to unplug the sub, i just put it in standby/auto mode
Usually the best option anyway, standby mode will shut it off after a pre determined time of inactivity anyway.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
I own 4 M&K subs of varisous sizes, when they are unplugged they will have a delay, then a 'pop'. I think it may be a capacitor discharge that is stored perhaps? When plugged in they make a similar 'pop' when energized. If I remember correctly, turning the volume down all the way eliminates the sound you hear??
Karl -
My JBL PB10 makes the same popping sound when i turn on my yamaha DSP E300.Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
if you have them completly turned off and not on auto it is normal for it to make some sound .It should'nt be a real loud pop.but a low thump.plus how loud do you have your reciever turned uped when you turn on the sub.ONKYO TX-SR607
PolkAudio Speakers
Front-Monitor 70's
Center-CS2
Sur-round-Monitor 40's
Sur-round Back-Monitor 60's
Subwoofer-PSW-505
Back fill in Bass PSW-10
LG 50"Black 1080P Plasma HDTV (50PS60)
LG Blu-Ray Disc BD390
