Blue ray drive PS3
greg2350
Has anyone replaced the blue ray drive on ps3. It seems my ps3 wont play blue ray but will play dvd.:(
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
AVR: Denon 3801
Sat: Directtv HD 10
Post edited by greg2350 on
Have you tried to download the latest software updates for the PS3 yet?
If you go to Settings>System Update, then it should have updates. If not, then I'm not sure what is happening.
I'd try another Blueray.
Process of elimination!~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox -
Thanks for the reply I have downloaded latest update and have tried 6 different blue rays 1 was unopened. It worked for 2 monthsTV: Philips 42" LCD 1080p
AVR: Denon 3801
Sat: Directtv HD 10
Center Speaker amp: Rotel 970 BX -
I haven't done it, but check YouTube - there should be quite a few videos out there.
I also see a lot of people on Craigslist fixing them for cheaper then what Sony asks for if you don't feel like trying it yourself. I can't imagine it being too difficult though. -
I'm debating whether I should replace it on my second PS3 that has the same problem, or just use it as a media player streaming from PC.
No doubt its the drive. I know sony was allowing people depending on what model you have to trade the broken ps3 plus $150 and get a refurb 120G slim from them. Not sure if that is still going on.
You can get the PS3 BD drive off ebay for I think $70 and fix it yourself
You can spend $150 and have Sony fix it but you probably won't get back the same model you have now.
You can buy the new PS3 120G slim for $299.
Good luck either way(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's
