New Pics of the Rig
DUDE!
Man, 86 the spunk rag, eh? Get you some of that rubber shelf lining or somthing.
NASTY.
BD (and completely repulsed) TI plan for the future. - F1Nut -
Weeeeeeeee! That is an old car rag! lol!
I am using rags with rubber bands above and below them. All I could find...works fine. There is actually *nothing* on the rag itself, just stained from wiping wax off of cars.
I am using that rag to tilt the speaker forwards.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
what is it with you guys and the rags, and the idea that everything is a jerk off rag :rolleyes:
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
Because Russ is envious of Micah- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
