Tube question
heiney9
heiney9 Posts: 25,497
edited January 2010 in 2 Channel Audio
I have a tube integrated amp it uses (4) 6V6's for output tubes and (2) 6SL7's for input/driver tubes. The amp is manually biased by (4) pots, one for each output tube.
My question is, when I change input/driver tubes do the output tubes bias change significantly? Should I re-bias the output tubes every time I change input tubes or will the input/driver tubes not affect the bias of the output tubes that much?
I rolled in a NOS pair of 1948 Tung-Sol JAN-CTL-6SU7GTY pair in tonight to make sure they work since I just bought them. The prior tubes were RCA 5691 "red base" and the bias really didn't change at all. Is this typical or did I just get lucky? It's a slight PITA to bias this amp and if I can avoid the hassle when I roll the RCA's back in that's fine by me.
Looking for first hand-knowledge and opinions. It seems to me in a SS amp changing the input/driver tranny's would affect the output tranny's, but maybe for a tube design that's not true.
I will say there is a night and day difference in sound between the RCA red base 5671 and the TS 6SU7GTY.
Post edited by heiney9 on
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    The better the tube amp the less I've found the need to bias. I usually bias after every complete retube but not much after that unless the soundstage noticeably shifts. If you're staying with the same tube and not using a substitution with different plate voltage, etc...you should be fine.
    I had a Radii amp that had to be biased everytime you thought about turning it on...and then after you touch it, then again after you went to the bathroom. It was ridiculous.
    edited January 2010
    That's the thing the RCA 5671 is a ruggedized version of the 6SL7 and the Tung Sol JAN 6SU7GTY is a military version of the 6SL7 and they both have pretty much identical characteristics. Probably why I didn't see a change in the bias. I've run the amp for a couple hours now and just rechecked the bias and it's right where it was when I powered it on.
    Guess I'll close her up and burn the Tung Sol's in and see if I want to keep them.
  • dorokusai
    edited January 2010
    heiney9 wrote: »
    I wouldn't think twice about it, just enjoy and check it in a week.
