protecting speakers
BuckeyeTim
Was wondering. Due to the issue of Adcom 565's with leaking capacitors (have had mine serviced once), is there a way to install some sort of in-line fuse or breaker that would protect the speaker in the unfortunate event of adcom meltdown?
Post edited by BuckeyeTim on
Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
If the service in question was to fix the leaky caps............you will never have to worry about them again most likely. So I wouldn't worry about it. Only some 565's and 585's had this issue because of a bad run (defective) of caps sourced from an outside manufacturer.
Thanks guys,
I somehow missed that post in my search.
Makes me fell a little more comfortable that I no longer need to perform the ritualistic Voodoo dance before I flip the power switches.
