protecting speakers
BuckeyeTim
BuckeyeTim Posts: 483
edited January 2010 in Vintage Speakers
Was wondering. Due to the issue of Adcom 565's with leaking capacitors (have had mine serviced once), is there a way to install some sort of in-line fuse or breaker that would protect the speaker in the unfortunate event of adcom meltdown?
Post edited by BuckeyeTim on
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    heiney9 Posts: 25,432
    edited January 2010
    If the service in question was to fix the leaky caps............you will never have to worry about them again most likely. So I wouldn't worry about it. Only some 565's and 585's had this issue because of a bad run (defective) of caps sourced from an outside manufacturer.
  • BuckeyeTim
    edited January 2010
    Thanks guys,
    I somehow missed that post in my search.
    Makes me fell a little more comfortable that I no longer need to perform the ritualistic Voodoo dance before I flip the power switches.
