Mortite Speaker Seals For SDA's
124
  • PolkMaster1
    PolkMaster1 Posts: 847
    edited January 2010
    Forgot to mention, some mortite does show up around the tweeter cutout area. Gotta try to clean that up.
    Statistics show that 98% of us will die at some point in our lifetime.
    The other 2% will work for WalMart.
  • PolkMaster1
    edited January 2010
    OK, got the second speaker done. Had to redo it as well as having to redo the first speaker. I forgot to read the disclaimer in this article that states "for the mindset of more is better", I had to remove the excess mortite I used around the drivers and speakers, so it took longer than expected, but its done. My leftover mortite looks like its been shredded.
    If you find yourself in this situation, use a knife to remove the excess!!! It will make the removal ALOT easier!!!
    But I have to say, so far, in a small sample size - the tremendous bass that comes from these speakers feels deeper. Still have to audition further, but its so far well worth it for a few dollars and two to 3 hours time if you do it right. Next stop - Dynamat Extreme!
  • PolkMaster1
    edited January 2010
    I dont know if this is my imagination - but another impression I am getting is that after applying the mortite, the speakers seem louder by 5 to 10dBs. Does anyone else have this experience after applying mortite to the 1.2TLs?
    I should also mention that when I was pulling out the drivers to apply the mortite, that it took some effort to pull them out. So I suspect that the seals held well on the drivers. Tweeters were pretty easy to remove. The PR took a little effort, but not as much as the drivers.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Wait till you try to pull them out now with the Mortite!!! We told you to wait until you're done with the Dynamat.;)
  • PolkMaster1
    edited January 2010
    Oh dear... Well, that will be a next weekend project.
  • hearingimpared
    edited January 2010
    I'll send you my crowbar!
  • PolkMaster1
    edited January 2010
    I've got a crowbar that only my GF can use. :eek::eek::eek:
  • hearingimpared
    edited January 2010
    Why does she need to crank it up?:D:p
  • PolkMaster1
    edited January 2010
    Seems that you guys can hear my speakers getting cranked from across the country.
    Toolfan66 Posts: 18,188
    edited January 2010
    Wish I could hear it. Better then hearing my wife yelling at me, man is she mad.
  • PolkMaster1
    edited January 2010
    Turn up those 1.2 TLs. Thats the reason why you got them in the first place. Problem solved. :eek:
  • Face
    Face Posts: 14,340
    edited April 2010
    FYI, my local K-Mart/Sears has Mortite on clearance for $3.50 a roll.
    I bought 4. :)
  • zingo
    zingo Posts: 11,258
    edited April 2010
    For any Northwest folks, Fred Meyer seems to no longer carry Mortite or similar products; I've checked with multiple stores. However, Ace Hardware does carry their own rope caulking, and I would assume it's the same material. It's $2.50 for the 30' roll in white or brown, or they also have a BIG roll. I'll be picking some up this week or next and giving it go on my Klipschs.
  • kcoc321
    kcoc321 Posts: 1,788
    edited April 2010
    If they have the brown that would be cool. I have the white from Lowe's, but there are times/ places it would be nice to have brown too.
    Thanks for the info.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited April 2010
    zingo wrote: »
    I recently "Mortited" my 7A's and 2A's using Ace Hardware's brand of rope caulk, and the results have been breathtaking.
    I got the 30' roll, which was about $2.50 or so, and it was enough to do both the 7A's and 2A's, with plenty left over.
    I can't imagine there being any difference with using the actual Mortite brand. Rope caulk is rope caulk. It's all the same stuff.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • hearingimpared
    edited April 2010
    Are you sure Curt? I know the Mortite doesn't bond. Have you looked into the possible bonding of the ACE rope caulk?
  • zingo
    zingo Posts: 11,258
    edited April 2010
    I read some review and it being the same as Mortite; properties and all. We'll let you know if our drivers end up glued to the cabinets. :D
  • hearingimpared
    edited April 2010
    zingo wrote: »
    Thanks you Sir!:)
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Update: I just went to Home Depot and they have original Mortite in the 90' roll for $5. I couldn't help myself at that price, so I picked up a box. It will be more than I need to seal my Fortes, but a little extra never hurt anyone.
    heiney9 Posts: 25,498
    edited May 2010
    It will make a very nice improvement. I did my 5B's just to get my feet wet before doing my 1C's. I haven't tackled the 1C's yet but very soon. I was very surprised the difference it made on the 5B's in my office rig.
    see here:
    http://www.polkaudio.com/forums/showthread.php?t=51420&page=6
  • zingo
    zingo Posts: 11,258
    edited May 2010
    It made a nice improvement on my 5s and CRS+, so I expect it to make even more of an improvement on my Fortes as they leak a little with their current gaskets. Plus, it should help deaden those horns a little until I can truly deaden them.
  • Bobsama
    Bobsama Posts: 526
    edited May 2010
    What's the diameter of that mortite?
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • zingo
    zingo Posts: 11,258
    edited May 2010
    Not sure, but it's just the standard rope.
    edited May 2010
    zingo wrote: »
    Looks to be the same size I used. Just be sure to apply even pressure on the drivers to flatten it out a bit before **** and then check your screws a few times within the week. As the caulk settles you'll need to tighten the screws a bit.
    You probably know all that :) If you've used it before
  • zingo
    zingo Posts: 11,258
    edited May 2010
    The Mortite can use a little massaging to get the driver flush on the cabinet, but it's not too tricky. The toughest part for me was the RDO tweeters as they have a narrow lip.
  • Face
    Face Posts: 14,340
    edited June 2010
    FYI, if you're going to use Mortite may seep into bare MDF. This shouldn't be an issue for Polk's, but possibly other speakers.
    edited June 2010
    That is one reason I thought about using polyurethane just to seal the wood from the mortite.
  • Face
    Face Posts: 14,340
    edited June 2010
    I'm glad these cabinets are ported. I removed the port and pushed from behind on and off for a few hours until the woofer finally came out.
  • Hawkeye
    Hawkeye Posts: 1,313
    edited June 2010
    So I guess it would be advisable to dyna-mat before the Mortite?
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited June 2010
    I've got both Dynamat and Mortite coming from Amazon.com. I'll be removing crossovers, sending to Ben for the TL upgrade, and when I put them back together I'll have everything done all at once. Hopefully won't have to take them apart anytime soon.
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
