I need HELP........
sagasa
sagasa Posts: 127
edited January 2010 in Electronics
I bought a Harman Kardon Avr 7000 at a local Thrift store. Everything works except there is no sound on the subwoofer even if i run the test tone no sound coming from my sub. The front , center and surround speaker are all fine and set to small. I tried changing the cable still no sound but i can feel some vibration on the driver but no sound. Everybody can pitch in before i return this and also idont have remote and manual. HELP.
Front: Tekton Pendragon
Center: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2
Post edited by sagasa on
    edited January 2010
    Don't really know H/K menus that well..but if you can't get it to work and your sub has HIGH LEVEL Inputs for speaker wire and outputs as well. Just wire the old way...L/R to the sub first and then from the sub OUTS to the speakers...adjust the crossover from the sub.
    cnh
    tonyb Posts: 33,072
    edited January 2010
    He may have it turned off in the setup menu.
  • sagasa
    sagasa Posts: 127
    edited January 2010
    How can i turn on the set up menu. thanks
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
  • anton.chigurh
    anton.chigurh Posts: 239
    edited January 2010
  • sagasa
    sagasa Posts: 127
    edited January 2010
    Thanks for the manual, I paid $200.00 for this is this worth the money other than the sub no working all speakers are working. Any more suggestion on what to do.
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    $200 is a bit steep IMHO; You're getting into the range that allows for HDMI. I've seen Onkyos that are a few generations old sell for close to that.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    7000 series is a beast....I thought those things were going for $1500 or more new? My neighbor had/has one....I remember the set up procedures were lengthy.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
