I need HELP........
sagasa
I bought a Harman Kardon Avr 7000 at a local Thrift store. Everything works except there is no sound on the subwoofer even if i run the test tone no sound coming from my sub. The front , center and surround speaker are all fine and set to small. I tried changing the cable still no sound but i can feel some vibration on the driver but no sound. Everybody can pitch in before i return this and also idont have remote and manual. HELP.
Front: Tekton Pendragon
Center: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2
Post edited by sagasa on
Don't really know H/K menus that well..but if you can't get it to work and your sub has HIGH LEVEL Inputs for speaker wire and outputs as well. Just wire the old way...L/R to the sub first and then from the sub OUTS to the speakers...adjust the crossover from the sub.
He may have it turned off in the setup menu.HT SYSTEM-
lsi 9's -
How can i turn on the set up menu. thanksFront: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2 -
http://manuals.harman.com/HK/HOM/Owner's%20Manual/AVR7000%20om.pdf -
Thanks for the manual, I paid $200.00 for this is this worth the money other than the sub no working all speakers are working. Any more suggestion on what to do.Front: Tekton Pendragon
Surr.: Fxi5
Umc1
Xpr-2
Xpa-3
Xda-2
Erc-3
Xsp-1
Vtf-2 Mk3 x 2 -
$200 is a bit steep IMHO; You're getting into the range that allows for HDMI. I've seen Onkyos that are a few generations old sell for close to that.
7000 series is a beast....I thought those things were going for $1500 or more new? My neighbor had/has one....I remember the set up procedures were lengthy.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan
