Sub or Rears 1st?????????
Just got new speakers for L/R/C. Should I get a sub next or rears.
Post edited by Murray1 on
Both:)
I'd get the rears then sub. -
Both:)
+1, BASS is very important but creating a proper sound field comes first, but man ur HT experience will be lacking without a decent sub. -
Sub.
Having rear channels isn't necessary. I'd be more bothered by having a gaping hole in the low frequencies of the soundstage. The LFE track is usually more active than the rear channels.My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun -
A good subEquipment
Panasonic TC-P54S2 Plasma
Scientific Atlanta DVR
ONKYO TX-SR705 AVR Pre/Pro
Outlaw 7125 7 CH Power Amplifier
Toshiba A2 HD-DVd
Panasonic BD-30
Harmony 550 remote control
LSi9 ( Mains )
LSiC ( Center )
PSB Ambient 2 Dipoles
SVS 20-39 PCI Subwoofer -
I would get the sub. It adds a lot to the experience. Plus you could add some super cheap book-shelfs for surrounds. Heck you could grab something at a pawn shop till you can you can upgrade.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
It depends on your fronts. If your L and R can go 25 Hz or lower, I would have rears then sub. Other wise I would get the sub then rear. For me, good solid bass is very important for both music or HT.Living room
Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
Player: Oppo 95.
Amps: Bryston 4B SST, B&K Ref 200.7 S2.
Pres: B&K Ref 50 S2, Paraound P5.
Subs: Dual Rythmik F15HP subs.
Man Cave
Speakers: Martin Logan Vistas.
Player: OPPO 105.
Preamp: B&K Ref 50 S2.
Amp: B&K Ref 125.2 S2
Sub: Rythmik F12.
Sub management: SMS-1.
Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
Room treatment: GIK Room Kit #1. -
Get a nice sub first. It will upgrade your HT experience more than surrounds will. It sounds like you are planning on getting both, but just want to know which one first. For HT a sub is pivotal.
packetjones wrote: »I would get the sub. It adds a lot to the experience. Plus you could add some super cheap book-shelfs for surrounds. Heck you could grab something at a pawn shop till you can you can upgrade.
Agreed, the Sub will add lots of Fun to your HT.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Add one more vote for a sub, 3.1 is fine for the time being until you can get your hands on a set of surrounds. Depending on what you are running for your L/R/C a sub will be your next addition.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
+1 for the sub, thats probably going to be a bigger expense than the rears(usually).Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Get a good sub. Buy some used book shelf speakers for rears that look good in the room. No real need to spend lots of money on rear speakers IMO.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Sub(s)!I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
How are you guys providing advice on what he needs to do without knowing what front speakers he already has? Am I missing something?
It depends on what front speaker you already have. You will probably want a sub ultimately, but if you've already got large speakers up front you may benefit less from a sub. I've got a set of RTi10s set up in a small living room, and they're more than adequate for everything I need - in that scenario you'll get much more from adding surrounds than a sub. -
Thanks all. I have RTiA5's for L&R. Using a CSiA6 for my center. Thanks again.
editHT Rig
Blu-Ray- 80 GB PS3
wutadumsn23 wrote: »Depending on what you are running for your L/R/C a sub will be your next addition.
-JeffAsSiMiLaTeD wrote: »How are you guys providing advice on what he needs to do without knowing what front speakers he already has? Am I missing something?
That was why I put that at the end of my post, depending on what he was running for the rest of his system would dictate where he should go from here.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Here is Polks link for a set-up similar to yours...
http://www.polkaudio.com/homeaudio/rtia/systems.phpPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
