Sub or Rears 1st?????????
Murray1
Murray1 Posts: 193
edited January 2010 in Speakers
Just got new speakers for L/R/C. Should I get a sub next or rears.
Post edited by Murray1 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2010
    Both:)
    I'd get the rears then sub.
  • madnod
    madnod Posts: 79
    edited January 2010
    leroyjr1 wrote: »
    Both:)
    +1, BASS is very important but creating a proper sound field comes first, but man ur HT experience will be lacking without a decent sub.
  • mystik610
    mystik610 Posts: 699
    edited January 2010
    Sub.
    Having rear channels isn't necessary. I'd be more bothered by having a gaping hole in the low frequencies of the soundstage. The LFE track is usually more active than the rear channels.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • ALWALLER
    ALWALLER Posts: 40
    edited January 2010
    A good sub
    Equipment
    Panasonic TC-P54S2 Plasma
    Scientific Atlanta DVR
    ONKYO TX-SR705 AVR Pre/Pro
    Outlaw 7125 7 CH Power Amplifier
    Toshiba A2 HD-DVd
    Panasonic BD-30
    Harmony 550 remote control
    LSi9 ( Mains )
    LSiC ( Center )
    PSB Ambient 2 Dipoles
    SVS 20-39 PCI Subwoofer
  • packetjones
    packetjones Posts: 1,059
    edited January 2010
    I would get the sub. It adds a lot to the experience. Plus you could add some super cheap book-shelfs for surrounds. Heck you could grab something at a pawn shop till you can you can upgrade.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • suprafantx
    suprafantx Posts: 249
    edited January 2010
    It depends on your fronts. If your L and R can go 25 Hz or lower, I would have rears then sub. Other wise I would get the sub then rear. For me, good solid bass is very important for both music or HT.
    Living room
    Speakers: McIntosh XR100 Fronts, LSIM707 Fronts, LSIM 706 Center, LSIM 703 Surrounds, LSi/FX Surround backs.
    Player: Oppo 95.
    Amps: Bryston 4B SST, B&K Ref 200.7 S2.
    Pres: B&K Ref 50 S2, Paraound P5.
    Subs: Dual Rythmik F15HP subs.
    Man Cave
    Speakers: Martin Logan Vistas.
    Player: OPPO 105.
    Preamp: B&K Ref 50 S2.
    Amp: B&K Ref 125.2 S2
    Sub: Rythmik F12.
    Sub management: SMS-1.
    Headphones: HD800, HD380, RS220, SRH-1840. Headphone amp: Woo WA2.
    Room treatment: GIK Room Kit #1.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited January 2010
    Get a nice sub first. It will upgrade your HT experience more than surrounds will. It sounds like you are planning on getting both, but just want to know which one first. For HT a sub is pivotal.
  • danz1906
    danz1906 Posts: 5,144
    edited January 2010
    Agreed, the Sub will add lots of Fun to your HT.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    Add one more vote for a sub, 3.1 is fine for the time being until you can get your hands on a set of surrounds. Depending on what you are running for your L/R/C a sub will be your next addition.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    +1 for the sub, thats probably going to be a bigger expense than the rears(usually).
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • thuffman03
    thuffman03 Posts: 1,325
    edited January 2010
    Get a good sub. Buy some used book shelf speakers for rears that look good in the room. No real need to spend lots of money on rear speakers IMO.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    Sub(s)!
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2010
    How are you guys providing advice on what he needs to do without knowing what front speakers he already has? Am I missing something?
    It depends on what front speaker you already have. You will probably want a sub ultimately, but if you've already got large speakers up front you may benefit less from a sub. I've got a set of RTi10s set up in a small living room, and they're more than adequate for everything I need - in that scenario you'll get much more from adding surrounds than a sub.
  • Murray1
    Murray1 Posts: 193
    edited January 2010
    Thanks all. I have RTiA5's for L&R. Using a CSiA6 for my center. Thanks again.
  • wutadumsn23
    edited January 2010
    edit
    HT Rig
    Blu-Ray- 80 GB PS3
  • wutadumsn23
    edited January 2010
    -Jeff
    That was why I put that at the end of my post, depending on what he was running for the rest of his system would dictate where he should go from here.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • Knucklehead
    edited January 2010
    Here is Polks link for a set-up similar to yours...
    http://www.polkaudio.com/homeaudio/rtia/systems.php
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
