source direct feature
hondo55
what if any are the advantages of using the source direct feature on my marantz 6200 receiver
Post edited by hondo55 on
It takes all processing out of the AVR and sends the signal from the CD player directly to the amps.
So if you have a CD player that has a better DAC than the AVR it should sound better.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Just be aware that if you run a sub with your AVR and it is connected via the sub/LFE out, switching to source direct (or Pure Direct as some AVRs call it) will shut off the sub/LFE out -for some AVRs - and you'll get nothing out of your sub.
This is because in Source/Pure Direct, your AVR becomes a 2.0 Stereo Amp only - ie no .1 channel output for the sub.
Also ensure that when you go Source/Pure Direct that your AVR will default to set your Main speakers to Large to ensure that you get the full bass frequencies.
Some AVRs will not default Mains=Large in Source/Pure Direct so it may be worth while to save a secondary configuration on your AVR if it supports memory settings and have a configuration with Mains=Large for when you switch to Source/Pure Direct.
Good post Erik!
On my Marantz, on 7.1 input (AUX), it allows me to do the following:
7.1 input with processing (AUX)
7.1 Direct Input (Direct, Video and Display are on)
7.1 Pure Direct (Direct, Shut off all things Video including HDMI and Display)
So for SACD Multi-Channel it allows me to do 5.1 Source Direct too.
Btw, coming from B&K REF50S2, I am totally impressed with Marantz analog quality. It is impressive how it sounds. It passes the source as if there is no pre-amp in between (on Pure Direct) to the power amp. I am really enjoying the source as if I just got it yesterday.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
