IC comparison methodology
Erik Tracy
Erik Tracy Posts: 4,673
Suppose you have a CDP connected via analog ICs to a preamp and then another set of ICs to the amp.
And suppose you get another set of nice ICs.
Would it make a difference you think if, for comparison purposes, you only compare the new IC to the currrent IC at the CDP?
Or would it make more sense/difference to compare the new IC between the preamp and the amp?
Or, would all permutations have to be evaluated?
Post edited by Erik Tracy on
  • fbm211
    fbm211 Posts: 1,488
    edited January 2010
    I would do both.However.I will point out that many have said that you use the best ICs between source and pre to get the best results.So begin the testing there.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • Erik Tracy
    edited January 2010
    fbm211 wrote: »
    Ah...I'll start there but see if there is anything noticable between the pre and power amp as well.
    Thanks!
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2010
    I have an interesting comparison situation at the moment. One of my ICs between the pre and amp broke so I put a cheapo IC on the left rear channel while the IC is being fixed. Now I am hearing lots of detail from the right rear, and only obvious sounds from the left rear.
  • tcrossma
    tcrossma Posts: 1,301
    edited January 2010
    I always put my best IC's between my source and pre. But ideally, you'd have the same IC's throughout.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Erik Tracy
    edited January 2010
    tcrossma wrote: »
    So you subscribe to the "loom" philosophy? :p
  • tcrossma
    edited January 2010
    Erik Tracy wrote: »
    You lost me on that one...
  • Erik Tracy
    edited January 2010
    tcrossma wrote: »
    All IC's are 'loomed' into a consistent 'weave' for a given system to give best results.
  • Ern Dog
    Ern Dog Posts: 2,237
    edited January 2010
    I also heard more differences in the cdp to preamp IC than I did from preamp to amp IC.
    It really is a mute point for me though because I use the same for both to capitalize on the synergy.
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    I always use the best IC's @ source--->pre-amp position.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Hawkeye
    Hawkeye Posts: 1,313
    edited January 2010
    Erik Tracy wrote: »
    I do and believe looming is the best way to gage improvement or not.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
