IC comparison methodology
Erik Tracy
Suppose you have a CDP connected via analog ICs to a preamp and then another set of ICs to the amp.
And suppose you get another set of nice ICs.
Would it make a difference you think if, for comparison purposes, you only compare the new IC to the currrent IC at the CDP?
Or would it make more sense/difference to compare the new IC between the preamp and the amp?
Or, would all permutations have to be evaluated?
Post edited by Erik Tracy on
I would do both.However.I will point out that many have said that you use the best ICs between source and pre to get the best results.So begin the testing there.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Ah...I'll start there but see if there is anything noticable between the pre and power amp as well.
Thanks!
I have an interesting comparison situation at the moment. One of my ICs between the pre and amp broke so I put a cheapo IC on the left rear channel while the IC is being fixed. Now I am hearing lots of detail from the right rear, and only obvious sounds from the left rear.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
I always put my best IC's between my source and pre. But ideally, you'd have the same IC's throughout.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
So you subscribe to the "loom" philosophy?
Erik Tracy wrote: »So you subscribe to the "loom" philosophy?
You lost me on that one...Speakers: Polk LSi15
All IC's are 'loomed' into a consistent 'weave' for a given system to give best results.
I also heard more differences in the cdp to preamp IC than I did from preamp to amp IC.
It really is a mute point for me though because I use the same for both to capitalize on the synergy. -
I always use the best IC's @ source--->pre-amp position.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I do and believe looming is the best way to gage improvement or not.
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
