Unequal speaker cable length
Jetmaker737
I could save a bit of coin ordering cable just in the lengths I need... 8ft and 15ft.
Would there be any detrimental effects?
Post edited by Jetmaker737 on
Other than the audio Gods sending a bolt of lightning your way? No.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
It makes no audio difference with speaker cables being unequal length. Unless they where extremely long and short or of different gauge or incorrect gauge for the system , you will be fine at those lengths.
DanDan
I have always been told just the oppositeThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
From what I have read there is a difference but it may or may not be noticeable. Personally, that would be too big a difference for me.
Regards,
MikeModwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
Same here. I have had differences in speaker distances from the amp but I always kept the wire runs the same length.
The electrical travel time differences could not be heard but my OCD requires me to use the same lenght.Speakers: SDA-1C (most all the goodies)
the electrical travel time differences could not be heard but my ocd requires me to use the same lenght.
+1..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Funny... found this post in AVS forum:
http://www.avsforum.com/avs-vb/showthread.php?p=9836372#post9836372SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
I have them equal in my 2 channel system, but in my HT the FL, RL, and CC are 8', while the FR and RR are 16'. This is using 'good' speaker wire, and I cannot tell any difference from the different lengths. But, man o man did I hear a tremendous improvement when I went from hardware store 12 gauge to the 'good' speaker wire.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
my front three are all the same length, the surrounds are the same length.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Different lengths of speaker cables are a non issue until you push the limit at about 500'. Even then Superman would have a tough time hearing any difference between different lenghts.
Not the point Phil! Do you or would you use different lengths of speaker wire? I think not buddy.
Same here. (I hate when people do this with no link...)but I read somewhere that having your speaker cable lengths off by several hundred feet would be the same as shifting your head (ears included
) 1/2" off center from the "sweet spot."
Even if the distances from the amp are different, I'll have the total length of the cables be the same.
I think the key though is to keep the runs as SHORT as possible. -
hearingimpared wrote: »Not the point Phil! Do you or would you use different lengths of speaker wire? I think not buddy.
Joe, with my system layout the speakers cables are the same length. If by chance that wasn't possible, I wouldn't be the least bit concerned over it though. There just isn't any audible difference in different length speaker cables until you approach 500'...not likely in a home system. -
Jetmaker737 wrote: »Funny... found this post in AVS forum:
this ( http://www.avsforum.com/avs-vb/showpost.php?p=9838074&postcount=14 ) is the best post evah!! -
Posts like that is why I don't join that forum.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
pearsall001 wrote: »Joe, with my system layout the speakers cables are the same length. If by chance that wasn't possible, I wouldn't be the least bit concerned over it though. There just isn't any audible difference in different length speaker cables until you approach 500'...not likely in a home system.
No **** Sherlock but you are just as OCD as the rest of us!!!:D:p -
Amen Brother. It would be like World War III! -
With respect to two channel I always use the same lengths..but as for surround I often have different lengths for L/R surrounds because of the way I have to run the wire. Since the current travels at near light speeds...I think you'd be hard pressed to hear a diffference? I mean we're not talking about 700+ miles an hour (mach 1) but less than a light second (186,000 mpsecond)? No?
cnh
Even knowing that the difference most likely isn't audible, I couldn't use different lengths of wire. EXTREME ANAL RETENTIVENESS!!!:D -
I am always very suspicious of the human senses as a measurement tool, especially ears, which are much less sensitive than eyes.
That one isn't playing with a full deck.Political Correctness'.........defined
President of Club Polk -
i made my runs equal lengths. as mentioned previously, OCD commands this be done.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Quote:
Originally Posted by Keiko
OCD, as in Obsessive Cable Disorder?
Fixed it for ya.
LOL
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
but it is a fantastic forum with some really knowledgeable folks for the most part.. some of them can be asses though. -
hearingimpared wrote: »No **** Sherlock but you are just as OCD as the rest of us!!!:D:p
Hey Holmes, I'm ever more anal than you (if that's possible :rolleyes:). I use this method of measurement & kill two birds (salmon really) with one stone. Once I lay them out end to end, I then lay the speaker cable next to them stretching from nose to tail. Once I'm happy with "precise" equal measurements, I then grill them up for a superb dinner!!! :eek::D;) There you have it...spot on equal cable lenghts & dinner!!!!
http://afsjournals.org/doi/abs/10.1577/1548-8640%281967%2929%5B238%3AAMOMLO%5D2.0.CO%3B2?cookieSet=1&journalCode=ficu -
There is a difference but unfortunately my hearing isn't as sensitive as many of the audiophiles on this board and therefore can not hear the micro second difference, potentially due to the wax in my earsI think the point audioholics makes (which I agree with) is that [a] yes, there is technically SOME impact to different cable lengths but human ears are not sensitive enough to sense the effect.
While my hearing is "waxy" I always make sure my cables are of the same lenght anyway. Even with the HT set-up, cables are all of the same lenght. Despite the fact that I will not hear the difference, keeping my set-up balanced has the priority not counting that the extra lenght provides for any potential modification of the system.hearingimpared wrote: »Not the point Phil! Do you or would you use different lengths of speaker wire? I think not buddy.
Cheers!
Waxy Hears
DARE TO SOAR:
You might not always have the same exact layout and you might want longer lengths at some point. Pay for an extra 7 feet now or you might end up needing a whole set later.
Shorter the better for the fronts, surround will have to be longer of coarse but if one run is a couple feet longer than the other, no, you will not hear a difference. That said, what you don't want is 20ft of cable coiled up on the floor to a speaker 8 ft apart.HT SYSTEM-
lsi 9's -
186,000 miles per second: It is not just a good idea, it is the law.
