Unequal speaker cable length
Jetmaker737
Jetmaker737 Posts: 1,113
edited January 2010 in 2 Channel Audio
I could save a bit of coin ordering cable just in the lengths I need... 8ft and 15ft.
Would there be any detrimental effects?
Post edited by Jetmaker737 on
    treitz3 Posts: 19,967
    edited January 2010
    Other than the audio Gods sending a bolt of lightning your way? No.
  • mantis
    mantis Posts: 17,332
    edited January 2010
    It makes no audio difference with speaker cables being unequal length. Unless they where extremely long and short or of different gauge or incorrect gauge for the system , you will be fine at those lengths.
    Dan
    Dan
    nooshinjohn Posts: 25,901
    edited January 2010
    I have always been told just the opposite
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited January 2010
    From what I have read there is a difference but it may or may not be noticeable. Personally, that would be too big a difference for me.
    Regards,
    Mike
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Same here. I have had differences in speaker distances from the amp but I always kept the wire runs the same length.
  • thsmith
    thsmith Posts: 6,082
    edited January 2010
    The electrical travel time differences could not be heard but my OCD requires me to use the same lenght.
  • Face
    Face Posts: 14,340
    edited January 2010
    thsmith wrote: »
    the electrical travel time differences could not be heard but my ocd requires me to use the same lenght.
    +1...
  • Jetmaker737
    edited January 2010
    thsmith wrote: »
    Funny... found this post in AVS forum:
    http://www.avsforum.com/avs-vb/showthread.php?p=9836372#post9836372
  • BlueFox
    BlueFox Posts: 15,251
    edited January 2010
    I have them equal in my 2 channel system, but in my HT the FL, RL, and CC are 8', while the FR and RR are 16'. This is using 'good' speaker wire, and I cannot tell any difference from the different lengths. But, man o man did I hear a tremendous improvement when I went from hardware store 12 gauge to the 'good' speaker wire.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    my front three are all the same length, the surrounds are the same length.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • pearsall001
    pearsall001 Posts: 5,256
    edited January 2010
    Different lengths of speaker cables are a non issue until you push the limit at about 500'. Even then Superman would have a tough time hearing any difference between different lenghts.
  • hearingimpared
    edited January 2010
    Not the point Phil! Do you or would you use different lengths of speaker wire? I think not buddy.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    thsmith wrote: »
    Same here. (I hate when people do this with no link...)but I read somewhere that having your speaker cable lengths off by several hundred feet would be the same as shifting your head (ears included :D) 1/2" off center from the "sweet spot."
    Even if the distances from the amp are different, I'll have the total length of the cables be the same.
    I think the key though is to keep the runs as SHORT as possible.
  • pearsall001
    edited January 2010
    Joe, with my system layout the speakers cables are the same length. If by chance that wasn't possible, I wouldn't be the least bit concerned over it though. There just isn't any audible difference in different length speaker cables until you approach 500'...not likely in a home system.
    edited January 2010
    Posts like that is why I don't join that forum.
  • hearingimpared
    edited January 2010
    No **** Sherlock but you are just as OCD as the rest of us!!!:D:p
  • hearingimpared
    edited January 2010
    treitz3 wrote: »
    Amen Brother. It would be like World War III!
    edited January 2010
    With respect to two channel I always use the same lengths..but as for surround I often have different lengths for L/R surrounds because of the way I have to run the wire. Since the current travels at near light speeds...I think you'd be hard pressed to hear a diffference? I mean we're not talking about 700+ miles an hour (mach 1) but less than a light second (186,000 mpsecond)? No?
    cnh
  • hearingimpared
    edited January 2010
    cnh wrote: »
    cnh
    Even knowing that the difference most likely isn't audible, I couldn't use different lengths of wire. EXTREME ANAL RETENTIVENESS!!!:D
    F1nut Posts: 51,722
    edited January 2010
    I am always very suspicious of the human senses as a measurement tool, especially ears, which are much less sensitive than eyes.
    That one isn't playing with a full deck.
  • BIZILL
    BIZILL Posts: 5,432
    edited January 2010
    i made my runs equal lengths. as mentioned previously, OCD commands this be done.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited January 2010
    Keiko wrote: »
    OCD, as in Obsessive Cable Disorder?
    Fixed it for ya.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    Quote:
    Fixed it for ya.
    LOL
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • fluffy
    fluffy Posts: 71
    edited January 2010
    treitz3 wrote: »
    but it is a fantastic forum with some really knowledgeable folks for the most part.. some of them can be asses though.
  • pearsall001
    edited January 2010
    Hey Holmes, I'm ever more anal than you (if that's possible :rolleyes:). I use this method of measurement & kill two birds (salmon really) with one stone. Once I lay them out end to end, I then lay the speaker cable next to them stretching from nose to tail. Once I'm happy with "precise" equal measurements, I then grill them up for a superb dinner!!! :eek::D;) There you have it...spot on equal cable lenghts & dinner!!!!
    http://afsjournals.org/doi/abs/10.1577/1548-8640%281967%2929%5B238%3AAMOMLO%5D2.0.CO%3B2?cookieSet=1&journalCode=ficu
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited January 2010
    thsmith wrote: »
    I think the point audioholics makes (which I agree with) is that [a] yes, there is technically SOME impact to different cable lengths but human ears are not sensitive enough to sense the effect.
    There is a difference but unfortunately my hearing isn't as sensitive as many of the audiophiles on this board and therefore can not hear the micro second difference, potentially due to the wax in my ears :p
    While my hearing is "waxy" I always make sure my cables are of the same lenght anyway. Even with the HT set-up, cables are all of the same lenght. Despite the fact that I will not hear the difference, keeping my set-up balanced has the priority not counting that the extra lenght provides for any potential modification of the system.
    Cheers!
    Waxy Hears :)
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    billbillw Posts: 7,502
    edited January 2010
    You might not always have the same exact layout and you might want longer lengths at some point. Pay for an extra 7 feet now or you might end up needing a whole set later.
    tonyb Posts: 33,069
    edited January 2010
    Shorter the better for the fronts, surround will have to be longer of coarse but if one run is a couple feet longer than the other, no, you will not hear a difference. That said, what you don't want is 20ft of cable coiled up on the floor to a speaker 8 ft apart.
  • MLZ
    MLZ Posts: 214
    edited January 2010
    186,000 miles per second: It is not just a good idea, it is the law.
