Bob Carver still working?
"... You need to go out and listen to other powerful amps and listen to what the differences are...."
Ok.
For example, names of amplifier should I listen?
I want to learn about the topic.
My friend, the whole world of Hi-Fi awaits you to experience and listen to.
www.audiogon.com is your portal to try a few Hi-Fi pieces for a lot cheaper.
I don't want to name what amplifiers you should try because you'll think that I am picking on SunFire.
But if you insist to know the names, I could name many Hi-Fi amplifiers from many makers and it'll probably not end. I know some very rare ones which can't be bought even even if you want to.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Sorry Bernal! You need to go out and listen to other powerful amps and listen to what the differences are. SunFire makes some good amps but hardly stand at the top ranks (not even in the middle ranks).
SunFire amps are considered higher end for entry level amps (not top ranks).
A couple of reviews to refute your statement:
http://www.stereotimes.com/amp010500.shtml
http://www.audiophilia.com/hardware/ma11.htm
http://www.avrev.com/home-theater-power-amplifiers/stereo-amplifiers/sunfire-signature-stereo-power-amplifier.htmlTNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I remember the following quote:
"...The essence of design is control. The objet trouve may have its attractions, but the greatest accomplishments of art, science, or craftsmanship are accessible only to those who control their medium completely. Raphael's School of Athens could not have arisen as street art. The Beethoven Ninth Symphony could not have been improvised by an inexperienced amateur. Amplifier "design by listening" is a charming phrase, seeming to combine the process and the goal. But the charm is meretricious if it amounts to some "audiophile designer" wandering around in an electronic parts house sticking resistors, capacitors, and tubes or transistors together, hoping for some magical sound. That won't work. "You have to know what you are doing" is the motto behind real accomplishment.
When it comes to amplifiers, few others know what they are doing as well as Bob Carver..."
To complete that quote:
"When it comes to amplifiers, few others know what they are doing as well as Robert Carver. Whatever one thinks of the Carver challenge, where Carver claimed to be able to duplicate the sound of any amplifier (within power limitations) by modifying the circuit of one of his own, the very fact that he could get close proves a point: He can control the sound of his amplifiers to an extraordinary, perhaps a unique, extent. (Personally, I believe that he can do what he claimed, at least so nearly that the differences are unimportant. But that is beside the point here.)
When you listen to a Carver1 amplifier, you are listening to the sound Carver intended. I am not familiar in any detail with earlier Carver designs. But, to go straight to the point, the Sunfire is among the best of amplifiers. Never mind the reasonable price, nor the absurd question that has preoccupied some reviewers of whether Carver is a true High End designer-as if that were some mystic priesthood-nor the fact that the Sunfire is enormously powerful, which to some implies automatically, in a vast misunderstanding of how things work, a lack of refinement. The Sunfire stands in the top ranks, defying all such preconceptions.
In the realm of would-be ultimate amplifiers, there are the eccentric absurdities, the micro-watt single-ended triodes with their 8 ohm output impedances, that function as a combination of harmonic distortion generators and tone controls, much beloved of those discontented with the sounds actually recorded. Then there are serious attempts, both tube and solid-state, at accurate reproduction of the input signal. Many of these work very well indeed and come close to or even get to being good enough, given how bad speakers and source material are.
It is a curious, but not inexplicable, fact that these latter do not sound precisely alike. Much of the variation among them is attributable to what amounts to a choice of electronic parameters. As I shall discuss momentarily, a modicum of signal alteration is bound to occur, and choices arise from the type of signal alteration chosen. To my ears, the parameter choices of the Sunfire are highly consonant with music. In any case, such choices have relatively small musical impact. More to the point, the intrinsic behavior of the Sunfire, outside such more or less arbitrary and unimportant choices, is superior to virtually all others.
You can spend more money. Depending on your personal preferences and your speaker system, you might find an amplifier that sounded better to you. But you can't buy an amplifier that is demonstrably better, and you will have a hard time finding one that is as demonstrably good. Moreover, to my ears, you will even have a hard time finding one that sounds better even in that evanescent realm of personal preferences based on parameter choices. The Sunfire certainly stands in my own personal top echelon. Given this situation and the price of the Sunfire, it seems fair to say that the Sunfire redefines the situation of audio amplification. As of now, we have a whole new ballgame."
Taken from this review: http://www.regonaudio.com/Sunfire.htmlTNRabbit
Sunfire TG-IV
Well, I agree if you want to tell me SunFire can sounds very good.
But if you want to tell me SunFire is Top Rank in the High End due to what those reviews tell you, you have to do better than that since I've heard both Carver, SunFire and a couple dozens of Higher End Amps in my home side by side. Frankly, the days of M1.0 / M1.5 sounds the same as ML2 is over.
I am a Carver Fan but I also know (heard, owned, and experienced) where Carever and SunFire stands in the Audio industry. Carver ALS being a small exception to Bob's Creation.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Thanks for your reply.
I have a McIntosh in my stereo system but it is another world and a very different category.
I also have the MBL-8011AM amplifier and is excellent.
I like Sunfire ... has something special -
SunFire Guys,
Do not confuse yourself Power with Fineness in sounds. Dynamic comes from abundant of power. Fineness comes from careful Engineering to details.
If power and bang for the bucks is all you want, may be SunFire is the amp for you. But let's don't joke about it. SunFire is in the blink of chapter 11 if it's Top Rank.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
It's fine if you like SunFire! I know I like SunFire (and Carver) too. It's just that I like some other amps better than SunFire and Carver.
But why you said McIntosh and MBL is in different Category. What kind of different Category? I am curious what you heard the differences are.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
That is slightly ironic. Other than small, efficient, high power amplifiers, he is known for advocating the sound of an amplifier is unrelated to its technology. Why make an expensive tube amp if its sound is easily reproduced with a solid state amp, or so the theory is.
Because there is no such thing............PERIOD!
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
chargerman426 wrote: »Mark your an POS (:)) for even thinking that the man the myth the legen that is Bob Carver is a douchebag. He is the smartest man in HiFi. Bob was also looking in and helping Rita.
Hardly.........one of the better audio/guru designers...........but the smartest in HiFi now or then??? Hardly
You guys ought to stop berating him. #1 - Mark wasn't serious. #2 - He's actually pretty cool. #3 - He HAS made a niche for himself with his designs. I seem to remember another guy (with some help from a couple friends) do that with some speakers a while back...
Is it THE best all be all? Not really, but it is pretty damn good for the pricepoint. So give it a rest, on both sides... WTF... -
SunFire Guys,
I think EMO is bang for the buck, Sunfire is light years better than that IMHO, but there is much better gear out there beyond Sunfire. The question for me is can you do better for less than the cost of your left nut:)....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »I think EMO is bang for the buck, Sunfire is light years better than that IMHO, but there is much better gear out there beyond Sunfire. The question for me is can you do better for less than the cost of your left nut:)....
LOL..:rolleyes:
great description there John.
I can only imagine that my soundstage/presentation and whatever else I get from my Sunfire can only be altered, "to make it sound better" by changing frequenciesTo suit ones' preference but not the quality of sound.;)
I've yet to hear better than what I'm hearing now.And I still have to upgrade my SRS's caps...Most people just listen to music and watch movies. I EXPERIENCE them.
Everyone seems to some degree get caught up in a Name brand and it being being better or worse than something else, both Carver and McIntosh have made many different products SS and tube amps pre's and the like some were/are better than others. I have heard Sunfire amps that I liked better than some McIntosh amps and im sure there are amps made by McIntosh that I would like better than Sunfire and some tube amps made by Carver that I would like better.Thanks for your reply.
There is no one genius that stands out amongst all others in the audio world lots of different people have contributed many different things.
The 300 x 2 and 600 x 2 amps are hard to beat in their price range. Are there better products availabe? yes. Are there worse things one can buy for the same money? yes.
REGARDS SNOWWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Sounds like EMO kicks SunFire in the nuts then? But it's not true anyway, SunFire is bang for the bucks for good sound and I don't know about Emo amps to call them the same as SunFire. But I know one thing - Emo is of no Reference Quality Amps out there (period)!
To answer your question about the cost of better gear without sacrificing left nut, I still have both and no need to sacrifice anything yet. As the old saying goes, those in the knowing knows and nothing to do with the cost of nut, etc.
But I definitely feel pain for you if you think if that's what take to beat SunFire and kick it in the nut.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
REGARDS SNOWI remember the following quote:
I like Sunfire:) ... has something special -
I am glad I didn't title this thread as "Is Bob Carver still designing great equipment"
Three 20 amp circuits. -
Isn't that what the EMoettes tout? -
The company being close to chapter 11 or not has nothing to do with the quality of the sound...??
I'm not saying it's the best of the best, but I don't think it's the upper end of mid-fi, either.TNRabbit
Sunfire TG-IV
If you wanna know what Mr Carver is doing, just get your A$$ to North Carolina in September and you can ask him personaly.I'm sure that he would be happy to talk amplifier design or anything else for that matter.JC approves....he told me so. (F-1 nut)
You need cheaper nuts then.
Your not going to get a corvette for the price of a Ford, know what I'm saying ? Bang for the buck, as we say....yeah, but other than that, ya gets what ya pays for.
Aside from that and I'm not taking anything away from Bob Carver, his amps always sounded sterile to me, no life in it. His tube amps maybe different, I don't know.HT SYSTEM-
lsi 9's -
nobody likes there baby called ugly, a mid-fi head job is still head and that can't be bad.
RT1 -
Those who dis Bob haven't meet him. Guys like him and Nelson Pass are awesome. As for sunfire I'm not impressed. Some Carver amp's are pretty nice, but most are not very high end. My buddy's 9T's are pretty sweet.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I have nothing against Bob personally, he's a very innovative and passionate designer/audio guru. I have never really cared for any of his SS designs. Certainly nothing horrible just nothing that really stood out, IMO. As for the amp challenge...........there are passionate, accurate arguments for both sides.
I LOVE the fact that Bob is still doing stuff and attends audio meets and still has a passion for this hobby and is willing to share, discuss and educate others.
My earlier comments were directed at a couple of specific statements others made, not necessarily to deride Bob Carver on the whole.
the offer to audition my 600x2 still stands... I will STFU now:)....Those who dis Bob haven't meet him. Guys like him and Nelson Pass are awesome. As for sunfire I'm not impressed. Some Carver amp's are pretty nice, but most are not very high end. My buddy's 9T's are pretty sweet.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
The company being chapter has nothing to do with the sound quality. I was saying if it's making top rank amp for the cost of bang for the buck, it's a bit impossible to be near chapter 11? But again, it's hard to say in this Economy and any company can go belly up.
I am also not saying it's sounds worse or bad of any kind but just pointing out to Bernal that SunFire is not among top rank. I know SunFire amps don't sound bad. They are not the best either. I think it's the higher end in the entry level and the guys I know on Agon considered the same too. That's all I was saying too.
But if you consider the power output for top ranking, it could probably be one in that area. Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
Ok, and the MBL-8011AM ....
I never priced my nuts.... how much is 15 pounds of solid gold going for these days.:D
I know what you are saying bro... In this example the comparison would best be getting 90% of a Ferrari's performance for the price of a Corvette.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Are you saying the Sunfire is as good as the MBL? I don't get your remark.
Some people say MBL to be one of the top ranking in HiFi. But I have no experience with MBL amps so I can't comment whether MBL is top ranking or not.
But how does it sound compared to SunFire? You have both so you must know what sounds better.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
If MBL is the top ranking in Hi-Fi, I quit.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
