New Subwoofer Set Up Help Please
sickerthanvick
So I got a new Polk PSW110 for my surround sound in my room. Its a pretty big room and it sounds GREAT with movies! Really deep and loud, almost room shaking. But for music, it is significantly less so, just a little bass, any ideas on how to get more wall shaking bass from music, keep in mind that I have a receiver hooked up with the sub, a CS10 center channel, and 4 Polk T-15 bookshelf speakers. I have been playing music off of my PS3 and 360, mp3 format, have not tried a CD yet, didnt think that would really make a difference since the mp3s came from the CDs. Any opinions?
Post edited by sickerthanvick on
Treat the walls in your room and EQ your sub. Room EQ Wizard (REW) is free at hometheatershack.comSpeakers: SDA-1C (most all the goodies)
That is way too complicated for me, haha. Like I said it sounds perfect, really loud, crisp bass with movies, but very quiet with music. -
A LOT of music doesn't contain the low bass that movies have. What do you have the crossover cutoff/slope set at?TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Well Im 99% sure its set to 80hz, I was messing with that to see if it would help with the music, but there really wasnt a difference. I just wanna rock out to some metallica and have a little thump behind it! -
sickerthanvick wrote: »Well Im 99% sure its set to 80hz, I was messing with that to see if it would help with the music, but there really wasnt a difference. I just wanna rock out to some metallica and have a little thump behind it!
Upgrade your sub then, lol. Seriously though, the 110 is a good sub, but it sounds like you want more than it can do. The DSW series is a better movie/music sub and will probably be more to your liking. Just my $.02, and welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Most processors are set up to give 10 dB increase in LFE for movies. Music has no such bump. That's why it sounds lower.TNRabbit
Sunfire TG-IV
Hi there,
You may want to check your receiver settings. When playing music, your receiver may just process the two channel (L and R). Thus your subs are bypassed. My particular receiver (Denon) requires LFE + Main as the setting so bass is sent to the subs (below the crossover setting) when playing CDs.
MarcusLSi9 + LSiC + LSiFx
dual PSW 505
Integra DHC 80.2 Pre-Amp
Outlaw 755 Amp
OPPO BDP-93 universal player
BENQ W6000 Projector
Da-Lite120 inch diag screen.
BlueJeans Cables all around. -
Also a good point, forgot that, lol.
-JeffHT Rig
Blu-Ray- 80 GB PS3
