Monitor 40 issues
I was doing some SACD listening this weekend, when I noticed that one my 40s (which I use for rears) was buzzing. I'm worried that a driver or the tweeter has busted but i'm not sure why.. I play everything through the yammy and I usually stay between between -30db and -20db on the volume I pushed it to -15db while watching princess bride DVD this weekend but its Dolby Stereo so i'm pretty sure they didn't even get used or at least used minimally for that. Any idea what might be causing it or what I need to do.. I've emailed off to polk CS but haven't heard anything back yet..
Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22
TV 3.1 system -
Post edited by coolsax on
hmm good idea.. i'll check that outMain 2ch -
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
Just one of the speakers? Try switching it with the other and see if it follows. If it does then it could be in the cable or at the source.
+1, also call Polk directly. E-mail takes awhile. Their CS is second to none and will get you back up and running in no time if it ends up being the speaker.
-Jeff
1-800-377-POLK (7655)
9AM-5:30PM EST Mon-FriHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It may take some more testing but i think it might have been a connection... I switched sides and while doing so, I added some banana plugs to the ends of the wire that i've been meaning to do since Christmas.. well so far that seems to have fixed the buzzing problem.. hopefully that will fix will continue... thanks for the idea KeikoMain 2ch -
TV 3.1 system -
Cool, glad to hear you are back up and running. Sometimes those wires can loosen up if you move em around, the nanners was a good idea.
-JeffHT Rig
Blu-Ray- 80 GB PS3
Good job Mike, I knew we kept you around for something besides Kona coffee and pie!!
-JeffHT Rig
Blu-Ray- 80 GB PS3
it probably should've been something I should have thought of but being new to this whole thing I didn't.. now i'll know for next time.. don't just assume its the speaker hehMain 2ch -
TV 3.1 system -
