Monitor 40 issues
coolsax
coolsax Posts: 1,826
edited January 2010 in Speakers
I was doing some SACD listening this weekend, when I noticed that one my 40s (which I use for rears) was buzzing. I'm worried that a driver or the tweeter has busted but i'm not sure why.. I play everything through the yammy and I usually stay between between -30db and -20db on the volume I pushed it to -15db while watching princess bride DVD this weekend but its Dolby Stereo so i'm pretty sure they didn't even get used or at least used minimally for that. Any idea what might be causing it or what I need to do.. I've emailed off to polk CS but haven't heard anything back yet..
Main 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22
Post edited by coolsax on
  • coolsax
    edited January 2010
    hmm good idea.. i'll check that out
    Main 2ch -
    TV 3.1 system -
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    Keiko wrote: »
    Just one of the speakers? Try switching it with the other and see if it follows. If it does then it could be in the cable or at the source.
    +1, also call Polk directly. E-mail takes awhile. Their CS is second to none and will get you back up and running in no time if it ends up being the speaker.
    -Jeff
    1-800-377-POLK (7655)
    9AM-5:30PM EST Mon-Fri
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • coolsax
    edited January 2010
    It may take some more testing but i think it might have been a connection... I switched sides and while doing so, I added some banana plugs to the ends of the wire that i've been meaning to do since Christmas.. well so far that seems to have fixed the buzzing problem.. hopefully that will fix will continue... thanks for the idea Keiko
    Main 2ch -
    TV 3.1 system -
  • wutadumsn23
    edited January 2010
    Cool, glad to hear you are back up and running. Sometimes those wires can loosen up if you move em around, the nanners was a good idea.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • wutadumsn23
    edited January 2010
    Good job Mike, I knew we kept you around for something besides Kona coffee and pie!!
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • coolsax
    edited January 2010
    it probably should've been something I should have thought of but being new to this whole thing I didn't.. now i'll know for next time.. don't just assume its the speaker heh
    Main 2ch -
    TV 3.1 system -
