Anyone notice delay with wireless Polk Sub?
Mr. Mojo
One reviewer mentioned that he noticed a delay in audio with the Polk 225 wireless subwoofer. I'm thinking of adding it as a 2nd sub just to balance out the bass in my family room. My main sub (Infinity PS210) would still cover the lowest bass (goes down to 20Hz). Another reviewer mentioned that he set his up that way and it worked well.
Has anyone else noticed a delay in the 225 audio?
Post edited by Mr. Mojo on
no delayTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
Thanks.
Any others? -
If there was a bit of latency, couldn't you just change the subwoofer distance to compensate? Then again, if you're using it as a 2nd sub, I guess that's not an option.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
I experienced no delay whatsoever with the 225i, even when placed behind another wall. Not that I would keep it there, curiosity just got the best of me.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I believe that was me.
I adjusted the timing on my reciever for what seemed to be a delay and all is well. I only noticed the delay when I was passing higher frequencies through the sub. It'd be difficult to impossible to really tell with sub bass frequencies. It totally could have been me and my perception too, and not the sub. YMMV. -
Thank you for your input.
It's definitely appreciated.
