Anyone notice delay with wireless Polk Sub?
Mr. Mojo
Mr. Mojo Posts: 53
One reviewer mentioned that he noticed a delay in audio with the Polk 225 wireless subwoofer. I'm thinking of adding it as a 2nd sub just to balance out the bass in my family room. My main sub (Infinity PS210) would still cover the lowest bass (goes down to 20Hz). Another reviewer mentioned that he set his up that way and it worked well.
Has anyone else noticed a delay in the 225 audio?
Post edited by Mr. Mojo on
  • eclimax13
    eclimax13 Posts: 168
    edited January 2010
    no delay
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • Mr. Mojo
    Mr. Mojo Posts: 53
    edited January 2010
    Thanks.
    Any others?
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2010
    If there was a bit of latency, couldn't you just change the subwoofer distance to compensate? Then again, if you're using it as a 2nd sub, I guess that's not an option.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
    treitz3 Posts: 20,038
    edited January 2010
    I experienced no delay whatsoever with the 225i, even when placed behind another wall. Not that I would keep it there, curiosity just got the best of me.
  • phuz
    phuz Posts: 2,372
    edited January 2010
    I believe that was me.
    I adjusted the timing on my reciever for what seemed to be a delay and all is well. I only noticed the delay when I was passing higher frequencies through the sub. It'd be difficult to impossible to really tell with sub bass frequencies. It totally could have been me and my perception too, and not the sub. YMMV.
  • Mr. Mojo
    Mr. Mojo Posts: 53
    edited January 2010
    Thank you for your input.
    It's definitely appreciated.
