Onkyo TX-SR707 $500 at Amazon
neokeelo
neokeelo Posts: 168
edited January 2010 in Electronics
Amazon has the Onkyo-TX-SR707 for $500 shipped. I wasn't sure where to post this but thought I would share it with you guys.
http://www.amazon.com/Onkyo-TX-SR707-7-2-Channel-Surround-Receiver/dp/B002DSMNPC/ref=sr_1_1?ie=UTF8&s=electronics&qid=1261578410&sr=1-1
My System
Pre/Pro - Integra DTR 40.2
Amplifier -Parasound 2205a
Paradigm Studio 60s V5 Mains
Paradigm Studio 590 V5 Center
Paradigm 20s - rear ( Wanted)
SUB - SVS PB12-NSD
LG PK250 60inch Plasma
Post edited by neokeelo on
  • raidersrule76
    raidersrule76 Posts: 471
    edited December 2009
    Audio deals of the day over in the clubhouse but thanks for the heads up
    Mark
    Sig to be updated after dealing with the insurance company:(:(:(
  • eclimax13
    eclimax13 Posts: 168
    how is this receiver...ive been looking for something to replace my denon avr 3806 ...i only use the processor part so im not really concerned about the power...would this be an upgrade?
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    Honestly I am kinda confused by the 3806's specs, it has HDMI, but doesn't appear to be able to decode the new HD codecs? Also, kinda confused as to whether or not it has the Burr Brown DAC's? If it doesn't then the 707 may be a bit of an "upgrade". The 707 also has more HDMI in's than the 3806, and I know for sure that it will decode the new HD codecs, and has the Burr Brown DAC's. Hopefully someone will be able to give you more info.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • vc69
    vc69 Posts: 2,500
    I prefer the Onkyo's sound to the Denon in this price range. Frankly, I just prefer Onkyo gear.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • wutadumsn23
    vc69 wrote: »
    As do I.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • Face
    Face Posts: 14,340
    FYI, it's currently on back order for 2-3 weeks. But, if you go to your local Best Buy, they will reluctantly match the price. ;)
  • wutadumsn23
    Best Buy carries Onk's? Not here....hmmmm
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
    They do online and in their Magnolia stores.
    cnh
  • Chameleon2
    Chameleon2 Posts: 112
    neokeelo wrote: »
    Is the 707 @ $500 shipped that much better than the 607 @ $350 shipped?
    I'd definitely get the 707 because that can be used as a Pre-amp in the future, the 607 cannot. The 707 also has THX certification, better DACs, more features and a bit more power, etc.
    But the most important thing is that it has pre-outs and that alone makes it more valuable....for example, when you try to resell it when and if you decide to upgrade!
    cnh
  • eclimax13
    edited January 2010
    i got the 707 and it was a huge difference...sounds are much clearer and more spacious...all localization is gone...and i got it for $479 the day after this was posted...very very impressed with onkyo
  • DeusExa
    DeusExa Posts: 491
    edited January 2010
    Wonder how this compares to the 805...
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2010
    Awesome deal! Years ago a 701/702 cost $799.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Gadabout
    Gadabout Posts: 1,072
    edited January 2010
    I have the 707 in my HT setup and it is being only used as a Pre/Pro. I'm happy with it's performance and sound.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
    edited January 2010
    DeusExa wrote: »
    I have an 805 myself, and while the new 707 series has a lot of new features...it does NOT have an amp section that is as good as the 805...pound for pound the 805 was the bargain of this last decade from Onkyo...look at the 1007 series if you want that kind of power in an Onkyo AVR.
    But I'm not sure how much of a difference that would make if you were not using the Onkyo's internal amps..as a pre...I'd guess the 707 is very good.
    cnh
  • eclimax13
    edited January 2010
    cnh wrote: »
    cnh
    Completely agree....nothing great when using the power section but used as processor only I'm not sure you can beat it in cost to value
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2010
    cnh wrote: »
    cnh
    +1. The 1007's amp section is surprisingly solid and is the closest thing to the 805 since its heyday. If you're using external power, the 707 would do the trick though.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • DeusExa
    DeusExa Posts: 491
    edited January 2010
    cnh wrote: »
    cnh
    Ah. I actually own an 805, just wondering if the newer offerings were necessarily any better in terms of either amp or preamp/processor.
  • wutadumsn23
    edited January 2010
    DeusExa wrote: »
    Probably not, the newer Onk's seem to be focusing on video and audio has taken a back seat. Although they did have the sense to put the Burr Brown DAC's back in the NR series, something they took out of my beloved 806. Unless you need the newer bells and whistles of the NR series, I would stick with your 805 and add an amp.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • wrigley
    wrigley Posts: 79
    edited January 2010
    Face wrote: »
    I was in best buy yesterday. They told me they won't match newegg or Amazon prices on anything!
    Mike
  • wutadumsn23
    edited January 2010
    wrigley wrote: »
    Mike
    That's a load of crap. Ask to speak to the store manager, I got my Sony tv from them for cost because I brought in an ad from an online company and asked if they would match it. They tried to charge me shipping, saying that I was going to pay that too, but they also charged me tax, which I would not have paid at the site. Store manager cleared it all up and even gave me my power center for 50% off. That was about 4 years ago so they may have changed their policy, but I got it done then.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
    edited January 2010
    -Jeff
    That unit has 1.1 HDMI repeaters so it can pass decoded LPCM but it cannot upconvert anything.
    The first Denon to have 480p processing was mine...the AVR2807. The 3806, I believe was one of the earliest Denons to have HDMI ins/outs.
    cnh
  • wutadumsn23
    edited January 2010
    Cool, thanks man. Guess I should have read it a little better, lol.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • wrigley
    wrigley Posts: 79
    edited January 2010
    -Jeff
    Both Best Buy and hhgregg told me the same thing yesterday. BTW the Onkyo 707 is $654.98 this morning on Amazon.
    Mike
  • wutadumsn23
    edited January 2010
    Hmmmm, they must have changed their policy, because I assure you it worked for me. I had to bury my head in the sand and act like a 4 yr old, but it worked, lol. As for the 707, I would seriously consider it. It doesn't have an overly powerful amp section, but it has pre-outs so an external amp will solve that problem. It does have all the bells and whistles you could want and the BUrr Brown DAC's.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    Maybe the Best Buy stores feel they have the upper hand now with CC gone. They probably feel that online stores are not competitors. Just guessing.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • wutadumsn23
    edited January 2010
    Could very well be. Like I said, it was 4 years ago, and CC was just around the corner, and don't think I didn't mention that too, lol.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • wrigley
    wrigley Posts: 79
    edited January 2010
    -Jeff
    Newegg has it for $599.00. hhgregg carries the 707. I have a $203.00 credit with hhgregg. I'll march in there at lunch time with the Newegg add and see if they will honor it. :)
    Mike
  • wutadumsn23
    edited January 2010
    wrigley wrote: »
    Mike
    Worth a shot, what's the worst that can happen? If not, then I strongly encourage you to just buy it from Newgg. They are a great company that many of your fellow Polkies (myself included) have bought from and will buy from again. They have free shipping and no tax, so other than having to wait a few days, you don't loose anything out of getting it from them. You can even buy the extended warranty as well.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited January 2010
    Best Buy does not match online pricing, nor should they be expected to IMO. How anyone can reasonably expect a local B&M store that has a much higher cost of overhead to maintain to match the price of somewhere online who can ship it out of a warehouse at a much lower overhead is beyond me.
    We have major entitlement issues in this country...
