speaker jumpers
2
  • kawizx9r
    kawizx9r Posts: 5,150
    edited January 2010
    kawizx9r wrote: »
    ok so the speaker cable would be plugged into the binding post where the jumper cable arrows begin correct?
    See how my jumpers are?
    Ok well let's say they're directional. Since I have them going from the bottom posts to the top posts the arrows will be pointing torwards the top post. It'd be reversed if you had your speaker cable coming from your amp going to your top posts....if that makes any sense.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • superjunior
    superjunior Posts: 1,632
    edited January 2010
    got it, thanks Freddy
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • gp4jesus
    gp4jesus Posts: 2,019
    edited January 2010
    Your theory would be incorrect. Polk has a price point to meet as do all other speaker companies. The plates are cheap and plentiful.
    Upgrading the caps and resistors in your speakers will also result in improved sound. Of course, Polk could use the better parts, but you'd pay a lot more for the speakers.
    Advise me on the details (caps and resistors) for RTi A* series speakers-I'ma tweekaholic. I've seen this mentioned in other threads-been too busy to ask about specifics.
    * A5s, A1s, CSi A6 center;
    thanx tony
    *all connected w/Premiere ICs
  • dskinner612
    dskinner612 Posts: 5
    edited January 2010
    How are MIT 2 cables for Polk RtI 10 and 8`s? anyone know.
    What about canare 4s11? thanks
    Audio stream?
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    edited January 2010
    I run 4s11, work's great! a lil' heat shrink and some techflex and you got yourself a set of $1,000,000,000,000,000,000,000.00 cable's :)
    Best way to do it IMHO. Quick & easy to make plus they'll cost ya less than a 12 pack of frosties :D I noticed quite an improvement when i made the switch :D
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • lightman1
    lightman1 Posts: 10,796
    edited January 2010
    Cables don't make a difference.....
    if you're deaf or a complete idiot.
  • packetjones
    packetjones Posts: 1,059
    edited January 2010
    This thread has sparked my interest. I am currently using bananas to connect the speakers. Would i just cut a small piece of wire and connect the 2 binding posts, then plug in the bananas? Would I insert the jumper replacement into the normal wire hole and screw it down tight?
    Thanks for the help. this seems like a really simple tweak and would like to see if it makes a difference at all.
    -edit-
    Also i have the A5's and A3's. Should I connect the bananas to the top or bottom does it matter? Currently I have it on bottom since i did not think it mattered.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
    F1nut Posts: 51,747
    edited January 2010
    Yes.
    Makes no difference.
  • packetjones
    edited January 2010
    Thanks for the quick response. Should i expect an improvement over the jumpers if i am just using some cheap speaker cable that i have laying around.
    Looks like i will be doing this and adding spikes this evening. Woohoo for cheap tweaks!!
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
    F1nut Posts: 51,747
    edited January 2010
    Trust your ears.
  • sTiLlLeArNiNg
    edited January 2010
    When i first did this i was only running 16g Rocketfish junk from FS and the difference was night/day! :)
    Media Room 7.1
    HTPC
  • DForeman
    DForeman Posts: 468
    edited January 2010
    Hooked up jumpers to front speakers this past weekend - noticed quite an improvement. Wish I had done this sooner.
    Am planning to do the same for center and back speakers now.
    (Signal Ultra speaker cables with Signal jumpers)
    Parasound P5 Pre
    Marantz AV 7703 Pre/Pro
    Outlaw 7500 Amp
    Marantz SA14s1 SACD/CD
    Rega Planar 2 TT
    Polk Audio Speakers: LSiM 705 Fronts, LC65FX Surround, LSiM 704c
    Oppo BDP-103
  • sTiLlLeArNiNg
    edited January 2010
    DForeman wrote: »
    SWEET! I had all my speaker's setup like that before, now i "bi-wire". You don't need high end stuff to get 'er done but if ya got it, you may as well use it :)
    Media Room 7.1
    HTPC
  • flyfisher
    flyfisher Posts: 220
    edited February 2012
    Lasareath wrote: »
    I have MIT speaker cables and I'm sure that jumpers from them are not going to be inexpensive.
    I guess before I buy from them I can just make up my own with some spare speaker wire and some spades.
    But I don't want to use spades because I can never get them to stay on. I'm using Bananas for my Shotguns so I can't do that. What are the spades called with the closed end, the ones with a circle in the middle?
    Sal,did you mean ring terminals? http://www.parts-express.com/wizards/searchResults.cfm?srchExt=CAT&srchCat=402&CFID=4350410&CFTOKEN=26830913
    Living Room Monitor 60's*CS2*FXi A6's*VSX 21txh*BD-P1590
    Spare Room RTi A7*CSi A6*FXi A4's*Epik Legend*BDP-05fd*DVL-919 Laserdisc/DVD player
  • Face
    Face Posts: 14,340
    Sal, pick up the larger Vampire spades from Sonic Craft, they're copper based so they won't degrade sound quality. I'm sure you can find a way for them to stay on.
  • Face
    Face Posts: 14,340
    You're using Cardas posts, correct? This will solve your problem: http://www.amazon.com/AudioQuest-binding-post-wrench-double/dp/B0009XQUAM
  • PiG
    PiG Posts: 35
    edited April 2012
    This is all very interesting. I recently stumbled upon this. I have a couple of questions as I'm planning to go the DIY route.
    To get rid of the brass plate could I do either of the following:
    1) Could I piggyback a closed screw banana plug on to the back of an open screw banana plug (where the speaker wire from the receiver is connected through the side) to make a jumper which would obviously have the other end of the DIY jumper plug straight into the back of the second post via another closed screw banana plug?
    http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2943&seq=1&format=2
    http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=2
    (apologies if I can't post those links, only posted for clarity of open/closed screw banana plugs.)
    2) How about using quad cable like the canare 4s11 where I would plug each inner strand to the four posts at the speaker end and then twist pairs of wires at the receiver end (basically making two 11AWG strands). Would this somehow degrade the signal since it's later split back to 4 strands of 12AWG? I'm thinking not but perhaps there's something simple I'm overlooking.
    Thanks!
  • Face
    Face Posts: 14,340
    edited April 2012
    PiG wrote: »
    Thanks!
    This is what I would do. But, avoid Monoprice nanners, IMO they degrade sound quality due to their high brass content. Look for gold plated copper spades or a gold plated nanner with high copper content(Vampire, WBT, etc...).
  • PiG
    PiG Posts: 35
    edited April 2012
    Face wrote: »
    Nanners = banana plug ? If so, they claimed to be copper construction, which is why I was looking at them. Marketing hype perhaps?
  • Face
    Face Posts: 14,340
    edited April 2012
    I can promise you they're not pure copper, they'd be priced MUCH higher. It's an alloy with a small percentage of copper.
  • PiG
    PiG Posts: 35
    edited April 2012
    Face wrote: »
    Damn marketers... thanks for the heads up!
  • PiG
    PiG Posts: 35
    edited April 2012
    PiG wrote: »
    I checked out the WBT's WOW you weren't kidding about much more expensive... at the most basic level of wiring a 5.1 system were talking between $720 and $1000+ (not incl. tax and shipping and crimp tools) for 20 plugs. WOW!
    This hurts I might have to go with the el chepo variety afterall :(
    Bare wire isn't that bad... is it? :0
  • Face
    Face Posts: 14,340
    edited April 2012
    Vampire's connectors(spades, nanners, etc...) are currently 20% off at Sonic Craft: http://www.soniccraft.com/products/connections.htm
  • wolfman1138
    wolfman1138 Posts: 49
    edited April 2012
    OK, I have a question. After all the talk of speaker jumpers vs. plates and wire gauge, got me thinking. What gauge is the wire inside the speaker that Polk used? How does this compare with the plates?
    It occurs to me that we are spending tons of cash on cables and connectors, etc and we are only going to achieve minimal gains.
    Kind of like putting a bigger engine and better wheels on a car and still using a broom handle for the drive shaft.
    Has anyone replaced the wiring inside the speaker?
    My Home Theater:
    Mains: polkaudio RTi150
    Center: polkaudio CS350LS (modified)
    Side: polkaudio 65-RT
    Back: polkaudio RC85i Rear
    Sub: SVS SB13-Plus
    Receiver: Denon 4311ci
    Sony VPL-VW60 on a 92" Draper Premier screen
    Sony 52" XBR2
  • 62caddy
    62caddy Posts: 137
    edited April 2012
    You have it the nail on the head- IMHO.
    I've no wish to question anyone's judgement who opts to change out their jumpers in favor of something else. By the same token I would hope the same courtesy be extended to those who choose not to go that route.
    Main:
    McIntosh: MC 2155, MC 2125(x2), MR 80, C 32, MQ 101; Snell J7; Polk: RTiA7, RTiA9;
    Pioneer PL-518; A/T 440 MLa; Yamaha CD
    Vintage:
    McIntosh: MX110Z, MC 2505, MC 240, Thorens TD 145; Shure V15III; Altec 14, Boston T1000; Yamaha CDX 393 CD; Yamaha Cass
    tonyb Posts: 33,072
    edited April 2012
    It's not about the jumpers per say, but improving everything in the chain for a better signal flow. Brass is not the optimal for signal flow. Will it work ? Sure, can you do better ? Yep. Some have indeed changed internal wiring for better quality wire but to me thats a tad over the top. Improvements with changing out jumpers, cables, etc, are small subtle changes on their own, but when you add up all the small changes, you can hear real world differences.
    With that said, most who change out those brass jumpers probably won't hear a difference. It's that minimal. Over time and oxidation, the signal will degrade some. So the standard answer applies, if you don't try, you'll never know. Simple as that really.
  • PiG
    PiG Posts: 35
    edited April 2012
    I've seen other threads where someone has done or suggested that they would do this... It's a little out of my league right now so I won't be doing it.
    Your point is well taken.
  • PiG
    PiG Posts: 35
    edited April 2012
    62caddy wrote: »
    Yeah, I was very interested in trying this as a no hassle cheap fix to MAYBE get some improved sound but it seems that there are so many variables that when you try to do it "right" its no longer cheap... so I might try it with cheapo plugs or bare wire but then of course, if you don't hear any differences you blame the lack of quality components... bit of a lose lose situation IMO
    tonyb Posts: 33,072
    edited April 2012
    Pig,
    Most just use bare wire, extra speaker wire they have laying around, so the cost is zero, with nothing to lose and everything to gain, sounds more like a win-win scenario to me.
  • Face
    Face Posts: 14,340
    edited April 2012
    I'll take bare wire over cheap connectors any day.
