Connecting Headphones with no factory Headphone Jack
inspiredsports
inspiredsports Posts: 5,502
edited January 2010 in Electronics
I have a pair of Sennheiser HD 570 (I believe 64 ohm), and a pair of Superlux HD 681 (32 ohm) headphones.
Both work fine with my old solid state NAD preamplifier that has a standard 1/4" female headphone jack. However, I've just purchased a vintage Conrad Johnson PV-7 tube preamp that does not have a headphone jack. The Conrad Johnson preamp does have a SECOND standard (RCA) OUTPUT, so it is capable of driving 2 power amplifiers at the same time.
I figured I could just use one of those cheap "Y" Adapters (2X Male RCA to 1X Female 3.5 Mini Stereo) to hook the phones to that second Conrad Johnson preamp output mentioned above.
But . . . the sound is just wrong, and I don't want to damage my preamp or headphones. I could be mistaken, but I don't believe the preamp is made to drive either 32 or 64 ohms from these RCA outputs.
I'm wondering what circuity is used in factory installed headphone jacks to accommodate the wide range of from 32 (or fewer) - 300 ohms that various brands and models of headphones present to the jack?
Yes, I know I should buy a headphone amp, but I just spent my upgrade budget upgrading my Musical Fidelity X10v3 tube buffer. Maybe I can use the tube buffer to impedance match?
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels
Post edited by inspiredsports on
  • Pauly
    Pauly Posts: 4,519
    edited January 2010
    Start saving for yet another amp :)
    Pauly
    Life without music would
  • inspiredsports
    edited January 2010
    Pauly wrote: »
    Pauly
    Yep, I guess so. :(
    NAD SS rigs w/mods
    GIK panels
  • halo71
    halo71 Posts: 4,637
    edited January 2010
    Well....never seen or heard of it being done on a hifi amp. But I have seen guitar amps modded before with a headphone jack. Might try to Google that. Just a thought.
    EDIT: I, by a long stretch, am no expert on the subject. But something like this might be an option. Didn't read up on it much though. But there seems to be a ton of info on doing what you want out there.
    http://www.paia.com/proddetail.asp?prod=9605K
    EDIT #2: On second thought. Not so sure I would be cuttin' into a vintage CJ either.
    --Gary--
  • gdb
    gdb Posts: 6,012
    edited January 2010
    You might want to ask RichP over at Carversite! He would most likely have your answer.:)
    http://thecarversite.com/yetanotherforum/default.aspx?
  • inspiredsports
    edited January 2010
    gdb wrote: »
    Thanks.
    I've never been a big headphone user so I hadn't thought about what goes into driving loads much higher than 4, 6, or 8 ohms.
    My old gear generally had a 1/4" headphone jack, and I plugged in and everything worked fine. Now I'm learning there was always a specialized circuit behind those 1/4" jacks, and cost cutting is perhaps why many more modern designs don't have it.
    I've decided that no matter how much I want to use headphones, I don't want to be drilling into the Conrad Johnson. If there was a simple adapter that would plug into a left/right pair of RCA outputs on my preamp and provide a 3.5mm mini or 1/4" jack, I would possibly go for that.
    Otherwise, I now in the hunt for a good Musical Fidelity X-CAN v3. :)
    NAD SS rigs w/mods
    GIK panels
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    Yeah, just get a head-amp. You can pick up a MF soda can on the cheap.
  • inspiredsports
    edited January 2010
    dorokusai wrote: »
    Yep. I'm guessing it will be the same "cheap" route as my MF X10v3 tube buffer. :D
    $200 - X10 v3 tube buffer obtained from CP member
    $900 - 2 pairs MIT Shotgun IC's
    $230 - Rock Grotto "Little Pinkie" PSU
    $250 - Shunyata AC Power Cord
    $180 - Revelation Audio Labs Passage Reference Cryo DIN power cable
    $270 - Rock Grotto rebuild (new tubes, caps, resistors)
    $25 - Isopod Vibration Dampers
    $45 - Herbies Tube Dampers
    Total cost of $200 buffer . . . $2,100.
    The sound quality improvement it yields . . . PRICELESS !!! :eek:
    NAD SS rigs w/mods
    GIK panels
  • dorokusai
    edited January 2010
    I guess it all depends on how you look at it :D The MF head-amp is pretty nice, sure there are better but we're not talking much money here. I've owned the soda can thru the v8.
