Oppo BDP-83 Special Edition - Sabre 32 DAC
124
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    I actually placed my order on 12/08/09, but didn't ship the unit out until 12/22/09. They did turn it around fast. I can't wait to hear it.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Ron Temple wrote: »
    Well now the upgrade window is officially over (I think). vmaxer, you just got in under the wire :D. Enjoy.
    BTW, SVS is sending me a new amp.
    Cool. I hope that solves the problem. My SE should be delivered today. I am stoked. Are you experiencing any break-in improvement or is it too soon to tell?
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2010
    vc69 wrote: »
    I haven't spent anymore time with it in 2 channel last weekend...too busy. I'm assuming the sub problems were amp related, so I doubt if that's a break-in issue. From the start you'll notice the difference, don't worry. As far as improving with break-in, that's probably a combination of some pathways settling in with both the machine and your brain...as you get familiar you pickup more detail and hear more improvement. Have fun with yours and report back.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Ron Temple
    edited January 2010
    C'mon guys...whadja think?
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Daggum FedEx did not deliver it yesterday. I got it this morning and am staring it down, waiting for 6:00pm so I can get outta here and hook it up. :D
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    Tracking mine shows it should deliver tomorrow, but requires a signature. This is going to be an issue, since I am at work during the day. Hopefully I can get him to call my cell when he gets there and meet him somewhere on his route?? I have had to do this before.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Mike LoManaco
    Mike LoManaco Posts: 974
    edited January 2010
    I don't know about the Special Edition version of this player, but I haven't been too impressed with the performance of the standard model; I have been going back and forth with OPPO's support since the player arrived and we've corresponded with countless amounts of e-mails already trying to figure out the problems.
    For starters, after I reported to them that the DVD upconversion didn't look that "breathtaking" (as everyone is reporting it to be) with the Anchor Bay processor, they recommended I change these settings under HDMI OPTIONS:
    Deep Color: 36-Bits (instead of OFF)
    Color Space: 4:4:4 (instead of AUTO)
    They told me to leave De-interlacing and CUE Correction settings at AUTO, and when I pressed them about my display/any software right now not supporting Deep Color, they ensured me that keeping the BDP-83 to "36-Bits" will force the player to operate and sample at a higher, better rate than keeping it OFF, even if a display or software doesn't support it.
    Further, I ran the de-interlacing and processing tests on the included Spears & Munsil calibration Blu-ray, and these patterns seemed to fail on my BDP-83 -- where the ABT chip is supposed to "take care" of these ringing/jaggies/noise issues, the player exhibited horrendous jagged edges on these tests at 1080p which didn't make sense to me. Real-world material doesn't seem to be so bad, but these tests indicate the jaggies are still horrendously there. When pressed about it, OPPO suggested the problem is in my display, not their player. Still trying to figure out the proper configuration for my BDP-83.
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Then why are you posting in this thread?
    I have a feeling, given the info you have provided both here and at AVS, that you will not figure it out. If you are within the 30 day return window, I would recommend returning the player.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    vmaxer wrote: »
    Well, mine delivered:D
    I will have to wait until later this evening to connect it and try it out:(
    Any updates from others that have received theirs:confused:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Well...
    I was going to do a more comprehensive write up later.
    Initial impressions are very, very good. I will say that it took a couple or three hours of use before the initial edge smoothed out. I was a little wary at first blush but my concern faded with use. I looped a redbook cd overnight and will give it another listen tonite.
    Having said that, I listened for about 5 hours last night and never suffered any fatigue. The soundstage is improved and the background is much darker to my memory than the standard player. DSD is definitely better with the SE. "Gaucho", which I wasn't particularly pleased with on the old player sounded much better to me on the SE. I haven't spun any DVD-A yet.
    Overall, this is a marked improvement and I am very satisfied.
    Bare in mind, this is all 2ch analog. I don't do much critical listening to MCH music.
    More to come....
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    vc69 wrote: »
    Well...
    More to come....
    Thanks for the info and by all means please do a follow-up after more testing. I'm not very good at writing up reviews. I am also in the early stages experience-wise. Better for me to mostly listen at this point.
    I don't listen to much multi channel music at all. I do play a lot of DVD concerts and usually do that in 2 channel as well. Some SACD also, but again usually in 2 channel.
    I do use my OPPO to decode the new audio formats in Blurays since the Sunfire TGP 5 will not decode them:(
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • Ron Temple
    edited January 2010
    Mike, the S&M disk is going to show issues with your display and recommended changes shouldn't be done on the player unless there is some compensation involved. Setting changes should be on the display. If you're having Cadence failures, that's where the problem lies not on the player. I passed all the tests, but there were a couple that were a challenge for my display as well. Nothing to be done about that. As for forcing 36bit color...I know my display can't go above 30bits and I leave it on auto.
    As for DVD upscaling quality. A bad transfer on a DVD will get marginally better, but it's still a bad transfer. A good transfer will upscale to near BD quality...depending on your display. I've had 3 upscaling DVD players, an Oppo 971, a 980 and a Sony BD S300. They were all pretty good, but the BD83 is hands down in another class. Previous upscalers would provide more pixels to faces and some background, but color always seemed a bit washed out...with the Sony being the worst. The 83 always provides a bright and colorful picture with more background detail. If you're not seeing it, then return it and get something cheaper.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Ron Temple
    edited January 2010
    vc69 wrote: »
    Well...
    More to come....
    I spent a couple of hours in 2 channel on Monday night playing Redbook CDs, Alan Parsons Gaudi, Supertramp Crime of the Century and Steely Dan Aja. I've probably got 20-25 hours total on it. The interior detail on fundamental notes is pretty stark. Before I'd hear the note or riff, the instrument and it would be good. Now I hear that plus the nuance from that particular recording session, whether it be fingering, fuzz or filtering. Also detail buried in cords is brought forward so that ensemble playing sounds like there are more instruments contributing than before. Lead vocals seem to be brought forward and background vocals recessed...meaning imaging is placing the background singers behind the lead on stage (at least on the AP disk...SDs singers were setup slightly different). All in all, SDAs have always made studio recordings sound live. Now they sound "liver".
    vc69, I heard an edge to vocals initially too...now it's smooth as silk.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Mike LoManaco
    edited January 2010
    vc69 wrote: »
    Because to date, this is really the only comprehensively focused thread on this site for the Oppo, period. Furthermore, I was having previous conversations in here and simply continued posting my thoughts/feelings on the non-SE model.
    I'm not, and it was purchased and given as a gift.
  • Mike LoManaco
    edited January 2010
    Ron Temple wrote: »
    The S&M disc is only going to show issues with a display if the Primary Output is changed from HDMI to component as with HDMI, the ABT chip is in full implementation (I discussed this tirelessly with the company). But I am not bypassing the ABT processor, so what I am seeing must be a result of the player's scaling abilities. And every test on the S&M disc failed in this regard.
    With 36-Bits Deep Color, I went back and forth dozens of times -- literally -- with Oppo, and they continued to suggest and recommend keeping my setting to 36-Bits for maximum performance from the player itself. They also informed me that my Sony display natively samples at 4:4:4 for Color Space.
    Still, I find it baffling that real-world DVDs don't show the ringing or jaggies for the most part when played back on my BDP-83, yet the test patterns are exhibiting wildly aggressive examples of this.
    I can understand this; I know the ABT processor won't make a bad transfer look like a better one, but I just expected more from this solution as I was finding most DVDs didn't look that much better than on my previous Panasonic BD player, and that's pretty tough to say.
    You don't think going the other way would be more effective -- that is, something more expensive than the Oppo? Something that would carry a Reon processor, perhaps? That may be the level of performance I'm looking for with standard definition upconversion.
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    No, it isn't. Here are two threads specifically focused on the Standard BDP-83.
    Oppo 83 Blu ray , who owns one?
    OPPO BDP-83 It is simply spectacular ....
    With me... and I said then that it was OT and should be carried to another thread.
    vc69 wrote: »
    Which is, btw, why I am interested in the SE upgrade. Sorry for going OT.
    Mike, I will be happy to take this to PM if you have further questions. Lets get back to the SE topic. It's quite compelling.
    Then perhaps it would be in your best interest to cooperate with those people willing and patient enough to work through this with you.
    They are discussing YOUR issue in YOUR thread: http://www.polkaudio.com/forums/showthread.php?p=1239595#post1239595
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Mike LoManaco
    edited January 2010
    vc69 wrote: »
    I didn't get a notice for anyone replying in that other thread -- hence, why I didn't know if anyone was. I don't know where you're getting the notion that I'm "not cooperating" with these people; I just now saw the replies.
    I'll unsubscribe from this thread due to that fact.
  • snow
    snow Posts: 4,358
    edited January 2010
    vc69 wrote: »
    Agreed I think that if you are having this hard of a time setting up your player perhaps it's best to simply move on. My oppinion is that either one of three things are occuring here, either the player is defective in some manner or that the operator is too dense to figure it out or last, that like in some other threads the poster has an agenda of their own and by running down the abilities of an audio/video item others will see this and shy away from that product.
    Just my 2 cents.
    REGARDS SNOW
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    I'm taking the afternoon and tomorrow off to go home and listen to this player. I spent about 4 more hours with it last night and I am loving it more and more. This thing is absolutely stunning with regard to the image and detail I am hearing. I haven't owned any high-end players, but I have heard a few. This player is on par with best I have ever heard. In my system, to my ears, it is absolutely amazing. I am a very happy owner. :)
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • snow
    snow Posts: 4,358
    edited January 2010
    vc69 wrote: »
    Good to hear positive statements. Is there anyone in your area that has a highend CD or SACD player that you could get together with to compare this player against theirs?
    REGARDS SNOW
  • Ron Temple
    edited January 2010
    snow wrote: »
    REGARDS SNOW
    snow, see Face's post # 75, there's a review from a guy on audioaficianado.com that compares the SE to a high end player. As expected, it comes close. The least that can be said about this upgrade is that it gives you a big slice of high end at a marginal price, plus you get a stellar blu-ray. Hell, you've got modders adding $3gs worth of upgrades on this platform if you really want to trick it out.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • snow
    snow Posts: 4,358
    edited January 2010
    Ron Temple wrote: »
    Thanks for the info, It was a very informative read. It appears that as I have been thinking that as technology in chips increase that it is more important to have the cutting edge chips even with a cheaper looking perhaps not as well made player than something made even a few years ago at a much higher price and better fit and finish.
    REGARDS SNOW
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    I've been playing with mine a bit and so far I love it!! I put the Layla and other Assorted Love Songs SACD on this morning and went to work and let it repeat over and over. I came home at lunch and put in a Stereophile "burn in" track on and let it repeat until I got home at around 5:30. This seems to have helped, I could hear a difference in Millage Gilbert's voice compared to last night;)
    I have played several CD'c and SACD's and am happy with the upgrade. I hear some small details I hadn't before.
    Using a CD I compared the sound using the Oppo's DAC's (analog outputs) against the Sunfire TGP5's DAC's (using the digital out) and the Oppo sounds better to me.
    I am not a pro, nor do I have a lot of experience as others here do, so take this lightly:o
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    Things have definitely settled down. Much like Ron said, the vocals have lost their edge and in general upper mids are smooth and detailed. I believe the upgrade is indeed worthy and for anyone thinking of purchasing the SE, worth the price tag.
    To say that I use this player primarily for music is an understatement. I initially purchased it as a UDP because my old Pioneer DV-578A was showing it's age and frankly had quit loading DVD's. It seemed like a great value based on the fact that it played everything and I had recently purchased a LCD panel, receiver and new Polk Monitor 50's, and wanted an excellent source to take advantage of the new gear. Thus began a journey...
    I found myself listening to it frequently and wanting more. The 50's were not cutting it for me so I did some inquiring at AVS in a thread Ron Temple frequented. He suggested looking for some older Polks and his advice was taken to heart. I ended up with a set of minty LS90's and a CS350LS and relegated the 50's to rear surround duty, where they serve quite nicely.
    I have an extensive music collection and found myself rediscovering it with the Oppo as the catalyst. I needed some power and a pre-amp. Again, following Ron's advice, I found a TFM-35x and scored it on Ebay. Realizing where I was heading, a friend of mine, who currently spends most of his time on the road with several bands as a FOH system tech, offered to ship me his VTL tube pre-amp which had been sitting in storage along with a couple of other goodies (a Rega Planet CDP, awesome Cardas and Transparent cables) to play with. Well, the higher up the food chain I went, the better the Oppo performed and the more I listened to music. But the more I wished the Oppo was a little less "harsh". Having had the Rega, I wanted the smooth silky mids and low end but the detail of the Oppo. Mind you, I would always return to the Oppo as my preference. The Rega was just too dark, not enough detail, and the image was 2 dimensional. Smooth yes, but not what I was looking for. The Oppo was far more detailed with a much wider and taller stage. Just a tad edgy. I tried several IC's and finally settled on some Transparent 100's for the Oppo. In fact, I love the Cardas but I cannot afford the cables my friend loaned me and he is willing to part with the Transparent sets so they became my "wire loom" as Max and RT1 would put it. But I digress...
    When Oppo offered the the SE upgrade I did some reading and thinking. Investing another $300 in the upgrade at Christmas time is not easy on my budget, and I would have close to $900 (shipping and an extended warranty from my first purchase) in the thing. Maybe I should just look for a dedicated SACD/CD player. But, the Oppo is worthy, I already have it and reports were coming in and they were very positive. So I took the plunge. Almost at the same time Ron did.
    So there is the story of how I arrived at the place I am now. The SE is the centerpiece of a very music centric HT setup and plays the solitary role as digital source for my two-channel rig. I am a happy camper. I realize that there are excellent players out there, many of which I will never hear, much less own. But I have heard some nice rigs. I am not left wanting with my current setup. No doubt there will be upgrades and replacements. That's just how we are. I am no different. But this is a very musical player and I have good enough gear to be able to tell. Subtle detail and nuances are readily revealed. That is the hallmark for me. I have to be able to actually hear the differences in cable, equipment and mixes or I am not happy with my rig. Well, I am there.
    The SE is a new level for me. I have been quite surprised at the difference the upgrade made. I think Ron summed it up well in saying:
    "The interior detail on fundamental notes is pretty stark. Before I'd hear the note or riff, the instrument and it would be good. Now I hear that plus the nuance from that particular recording session, whether it be fingering, fuzz or filtering. Also detail buried in cords is brought forward so that ensemble playing sounds like there are more instruments contributing than before. Lead vocals seem to be brought forward and background vocals recessed..."
    That too is my experience. Greater detail, wider stage with depth and height and excellent balance. Bottom end is solid and not over emphasized, or perhaps a better way to put it is the top end is not over emphasized. I always feel as though the Rega is either emphasizing low frequency content or rolling off highs. Detail is lost. Not so the SE. The damn thing just sounds "accurate". It's honestly an amazing value. I cannot imagine besting it for less money and possibly for quite a bit more. In comparing it to the Rega Planet, it is a no contest. The Oppo is a hands down winner. The fact that it is a stellar video source just adds icing to the cake.
    Hope that wasn't too long winded. Context is important and I hope I gave you guys an idea about how this player fits into my system, the budget it fits and ears it pleases.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • Ron Temple
    edited January 2010
    nice write up vc :cool:
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • engtaz
    engtaz Posts: 7,669
    edited January 2010
    Very nice write up. Thank you.
    engtaz
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    Sounds like we are happy:cool: I know I am:D
    Thanks for the write up!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    edited January 2010
    vc69 wrote: »
    Hello VC69, any updates from your additional time with the player??
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vc69
    vc69 Posts: 2,500
    edited January 2010
    vmaxer wrote: »
    Not really except to say that the redbook (CD) performance is much, much improved over the standard player in my opinion. I highly recommend the SE for anyone doing analog audio out from this player. I wish I could hear the NuForce to compare.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
