SDA Hierarchy
24
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    I've heard tricked out CRSs, CRS+s, tricked out 1Cs, tricked out 2.3TLs and tricked out 1.2TLs and I have to say I like the 1.2TLs best but then again I'm biased. I forget to mention that I owned the original SRS in the '80s.
  • dbaldus
    dbaldus Posts: 730
    edited January 2010
    When you guys are saying that the original SRSs have more of an emphasis on bass, are you talking about the non-TL versions such as the SRS 2.3 or just the original SRS 2?
    I only ask because I'm considering picking up a pair of mint SRS 2.3s and am trying to decide if I need to continue holding out for either the 2.3TL or 1.2TL.
    2-channel
    Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
    Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2
  • dbaldus
    dbaldus Posts: 730
    edited January 2010
    dorokusai wrote: »
    The 1.2 is the most overrated SDA and the 2.3 is probably the most well-rounded and would be my choice.
    When you say the 2.3, do you mean the 2.3TL or the original SRS 2.3?
    2-channel
  • hearingimpared
    edited January 2010
    dbaldus wrote: »
    I would hold out for the TL versions. If for no other reason than they have better tweeters.
  • Hamatym
    Hamatym Posts: 269
    edited January 2010
    The Orginal SRS's blade/blade connection and SRS-2's blade/blade connection are the Bassier speakers. Bluecomet can confirm the difference for sure, but I found anything with a Pin/Blade interconnection cable has a smoother sound, but less emphasis on the bass. I think it's a crossover difference and certainly not a Hz issue. He has every dang SDA know to man...ha ha and can comment to help you out
  • dbaldus
    dbaldus Posts: 730
    edited January 2010
    What if you consider that I would be replacing the 2.3s tweeters with RDO 194s? Is there still a huge difference between a 2.3 with RDO 194s and a 2.3TL with the "stock" tweets (SL3000s if I'm not mistaken).
    Mainly looking for a major upgrade from my 2As right now...
    2-channel
  • hearingimpared
    edited January 2010
    dbaldus wrote: »
    I think the RD0198s (replacement for the SL3000s) sound leaps and bounds better than the 194s.
  • bluecomet
    bluecomet Posts: 1,118
    edited January 2010
    You are going to notice a difference in particular at higher volume. The RDO 198's and SL3000s are more smooth in that area. The RDO 194's make a difference if you decide to get a non tl version SDA or SRS speaker and would recommend the upgrade. The original SRS and SRS 2 in particular had more emphasis on bass. Some people like the heavier bass sound. It's all in what you prefer.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
  • dbaldus
    dbaldus Posts: 730
    edited January 2010
    bluecomet wrote: »
    Well, for normal listening levels, would the original SRS 2.3 with RDO 194s and the 2.3TL with SL3000s be similar?
    Also, would the SRS 2.3 with RDO 194s be a significant upgrade from my SDA 2As with RDO 194s (which they do have, by the way)?
    I've just been looking for some 2.3TL or 1.2TLs for so damn long that I feel like I should bite on these 2.3 non-TLs to upgrade!
    2-channel
    Toolfan66 Posts: 18,077
    edited January 2010
    would the SRS 2.3 with RDO 194s be a significant upgrade from my SDA 2As with RDO 194s?
    YES!! and don't forget to spike them.
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2010
    Can't one just "TL" mod the non TL versions? Or is that really only possible on a few specific models?
    Just curious, because sometimes "holding out" can mean losing out on a rare local deal.
    ____________________
    Pool: Atrium 60's/45's
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2010
    My fav is the SRS 2, followed by the 2b and CRS+.
    As far as 'actual' heirarchy, Raife typed the following up for me several years back->
    1st Generation (1982): SDA 1.
    2nd Generation (1983): SDA 1A, SDA 2, and SDA CRS.
    3rd Generation (1985): SDA 1B, SDA 2A, SDA CRS+. The 3rd Generation also marked the introduction of the "Signature Reference Series" (SRS) line: SDA SRS, and SDA SRS 2.
    4th Generation (1987): SDA SRS 1.2, SDA SRS 2.3, SDA 1C, SDA 2B, and SDA CRS+. All SDA speakers received crossover and cabinet upgrades.
    5th Generation (1989): SDA SRS 1.2TL, SDA SRS 2.3TL, SDA SRS 3.1TL, SDA 1C, SDA 2B, SDA CRS+. The 5th Generation of SDAs saw the introduction of the SL3000 tweeter in the SRS line. The SL3000 tweeter provided a flatter, more acurate frequency response than the SL2000 tweeter. The SL2000 had a +5 dB resonance at 13,000 Hz.
    SDAs ceased production in 1991.
    edited January 2010
    mmadden28 wrote: »
    only possible on a few specific models, CORRECT!!
  • dbaldus
    dbaldus Posts: 730
    edited January 2010
    mmadden28 wrote: »
    From what I've read, to upgrade the 2.3s to 2.3TLs would require you to upgrade the crossovers, change out the woofers (since the 2.3s use 3 different types and the 2.3TLs use all the same), AND change out the tweeters to get it to a TL. So, in short, its a LOT more money than you would expect and there really wouldn't be anything left of the original 2.3 when you were done with it, so you might as well just buy the TL.
    mmadden28 wrote: »
    Haha... if only it were local. I'm looking at driving 5 hours one way to pick up these 2.3s, which is exactly why I'm trying to figure out if I should make the trip or not.
    If someone has a pair of 2.3TL or 1.2TLs that is 5 hours or closer to Minneapolis, I'd definitely make that drive instead of picking these up!
    But I definitely hear you and don't want to miss out on this deal as I've been looking for a pair of the big boys for a LONG time :)
    2-channel
  • dbaldus
    dbaldus Posts: 730
    edited January 2010
    RuSsMaN wrote: »
    Isn't this exactly what the RDO-194 (replacement for the SL2000) supposed to do? So what would be the difference between the RDO-194 and the SL3000?
    2-channel
  • erniejade
    erniejade Posts: 6,321
    edited January 2010
    Supposedly the rdo just sounds smoother especially if you play high volume. For regular volume, some people preferred the original over the rdo.
    Again sound is personal. What one likes might not be what someone else might like.
  • gdb
    gdb Posts: 6,012
    edited January 2010
    Another thing to remember is that not all SL2000s sound the same, there are diff. runs,diff. ages and different use/abuse histories. Some of the many that I have sound pretty good, while others sound like a Dentist's drill!:eek: I personally think that the better sounding 2000s are ideal for reproducing speaking/voice sounds in HT speaker applications.;)
  • mmadden28
    edited January 2010
    dbaldus wrote: »
    I was under the impression that the SL-3000 and the RDO-194 were one and the same. No?
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2010
    My sentiments exactly! :)
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited January 2010
    mmadden28 wrote: »
    SL-2000's are replaced by the RDO-194.
    SL-3000's (TL's) are replaced by the RDO-198.
    In my humble opinion, the RDO-198 is both more revealing AND smoother at the same time, than the RDO-194.
    The components in your crossover dictate which tweeter is required, and only a few models of crossover that were originally built for SL2000/RDO-194 can be modified to use the RDO-198.
    NAD SS rigs w/mods
    GIK panels
  • inspiredsports
    edited January 2010
    gdb wrote: »
    If in fact an SL2000 still sounds good to you, I can't imagine that condition will last for long as the tweeter ages.
    NAD SS rigs w/mods
    GIK panels
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2010
    Yeah... after 25 years or so the 2000's really start going downhill...
    Actually the 2000's were very sturdy, whereas the 3000's deteriorated with time.
    dorokusai wrote: »
    You know all about that Mr. Monitor Collection :D Did you ever get that picture?
    Not yet… I still have to pick up the 11’s from BMDP... :p
    More later,
    Tour...
    Vox Copuli
    edited January 2010
    I haven't heard SL3000s but considering all the R&D that went into them and the cutting edge technology of vapor deposition at that time? I would imagine that running SL3000s would not be a bad thing?
    And I also do not understand why this 3000 would disintegrate faster than an SL2000? The alloy was steel and aluminum over a polymide surface...no! All that sounds fairly indestructible? I have a set of titanium diaphragm tweeters that are about 20 years old and they show NO sign of fading?
    cnh
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    Tour2ma wrote: »
    Why aren't you staying at my house then?
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    cnh wrote: »
    cnh
    The plastic that the metal is deposited on deteriorates.
    Ben
  • Bubinga99
    Bubinga99 Posts: 283
    edited January 2010
    ben62670 wrote: »
    I hadn't heard that, but I have heard that the ferro-fluid of the day (and this isn't just Polk, but other manufacturers as well) begins to break down and become clumpy (which affects the tweeter's response in both electrical and mechanical ways).
    Speculating from that, it seems reasonable to assume the ferrofluid doesn't just become clumpy all of a sudden, so there's probably a period--possibly years--where its fluid properties are degrading from when it is new, but not to the point of becoming clumpy yet.
    That would probably change the tweeter response, since the ferrofluid properties are an integral part of the tweeter response. I'm just guessing about this part however, so take it with a grain of salt.
    In any case, there's no simple way to measure it, and it doesn't become clumpy after say 20 years in every SL3000, so there must be other factors involved besides just age.
    I've read speculation that lack of use for extended periods (i.e. years) and/or extended exposure to cold temperatures (like of the speakers were stored in unheated space) might be contributing factors. I haven't seen any official study though, so grain of salt again.
    heiney9 Posts: 25,447
    edited January 2010
    I still feel for most listening rooms (ie; the size most people have) the 1C's are the best SDA's; with either the 2.3 or 2.3TL and then the 2B w/TL mod coming in next.
    The "big boys" are awesome but they need breathing room and I would suspect there are many on here who have them set up in too small of a room.
    P.s. If you use excellent caps/resistors to them and add RD0's they just are simply superb!!!
  • hearingimpared
    edited January 2010
    You are correct Brock. My room is 19.5' x 11'. I have my 1.2 TLs on the long wall and am able to take full advantage of the positioning. My sweet spot starts at 6' 6" from the center line and goes back to a little over 8'. They sound wonderful.
  • dbaldus
    dbaldus Posts: 730
    edited January 2010
    How far apart do you have them?
    2-channel
  • snow
    snow Posts: 4,358
    edited January 2010
    heiney9 wrote: »
    What size room is optimal?
    REGARDS SNOW
