Looking for TFM75
Soundmind
Am starting a search for POWER !! WUHAHAHAHAH. How much should one of these be worth ?? Thanks..
Panamax M5100-EX HT Power conditioner
Yamaha RXV861 tuner
Carver TFM25 amp
Carver av-405 surround amp
Carver ct-17 Tuner
Sony BDP-S350 BluRay
Sony 222ES CD
Sony PS-LX520 Linear track Turntable
Panasonic 46" flatscreen
Polk LSI 15 mains
SVS PB-12 plus Sub
JBL center channel
Polk LSI 9 surrounds
Polk monitor 12 series II "old mains"
Yamaha RXV861 tuner
Carver TFM25 amp
Carver ct-17 Tuner
Sony 222ES CD
Polk LSI 15 mains
SVS PB-12 plus Sub
JBL center channel
Post edited by Soundmind on
The ones I have seen in the past couple of years have gone for in-between 1K to 1,400. I think the most I have ever seen up for sale in one year were 4, so be prepared with $$$ in hand so you can pounce on it when the time comes.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Two were on ebay this year that I can think of. Both were in the $1,500 range.
What do you plan to use them with?Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
SOmeone here has a really nice TFM-45 serviced in July 09 for sale:o
Seriously a 75 is nice. If you can find one I suggest a full service if it has not already been done recently.Speakers: SDA-1C (most all the goodies)
thuffman03 wrote: »Two were on ebay this year that I can think of. Both were in the $1,500 range.
Replace my TFM 25 for my 2 channel setup. TFM25 will remain on HT. Will be powering my Polk Monitor 12s with new amp.Panamax M5100-EX HT Power conditioner
Yamaha RXV861 tuner
Carver TFM25 amp
Carver ct-17 Tuner
Sony 222ES CD
Polk LSI 15 mains
SVS PB-12 plus Sub
JBL center channel
Polk monitor 12 series II "old mains" -
IMO, if you are powering the 12s, a TFM 35 or 45 would be more than enough.
My TFM-55 will make my 2.3tls sing. You ought to take a serious look at the TFM-45 that thsmith has for sale. Buy a used, un-updated one off ebay and you may find you have to spend an additional 400 to get it fixed. His in pristine condition.
>This message has been scanned by the NSA and found to be free of harmful intent.< -
I was thinking the same thing [thsmith's 45]. The 75 would be complete overkill for its intended use.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
It has cooling fans so that needs to be taken into consideration as well.SDA SRS 2.3TL's
SDA 2B TL's -
IIRC the Mon 12 is rated at 250 watts max. The 75 is an overkill in watts and dollars. If you could even find one for sale.>
Sunfire Stereo Grand 300x2 is an easy find and a great fit as wellThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Take a look at thsmith's TFM45. If I had the money I would buy it.( I have a TFM35x) His 45 has been serviced/upgraded and cosmetically looks very nice. You would be getting 375 watts/ch 8ohm, 500w/ch 4ohm. A nice upgrade from your 25.I bet your 12's would sound great with that amp!:DHT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
Polkersince85 wrote: »IIRC the Mon 12 is rated at 250 watts max. The 75 is an overkill in watts and dollars. If you could even find one for sale.
They are rated at 400 per channel. I barely get them going with the 25.Panamax M5100-EX HT Power conditioner
Yamaha RXV861 tuner
Carver TFM25 amp
Carver ct-17 Tuner
Sony 222ES CD
Polk LSI 15 mains
SVS PB-12 plus Sub
JBL center channel
Good luck finding a TFM-75. They are legendary. 750 wpc, dual mono design (two power cords) that require 2 dedicated 20 amp circuits for full power~TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
I thought it was 500W RMS? I could be wrong, not a genius when it comes to vintage Polks.
-Jeff
Edit: Disregard above info, just checked Polks website they are rated 20-400W. Carry on.
http://www.polkaudio.com/homeaudio/specs/recent/monitor12/HT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
The 45 would properly power them with plenty of headroom to spare.They are rated at 400 per channel. I barely get them going with the 25.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
agree, I had monitor 12s with a TFM-25 and I could push them all I wanted. A 45 would be coasting.Speakers: SDA-1C (most all the goodies)
Or the Sunfire sig 600 X2 would also fit the bill. With the sig, you can run the voltage out to the woofer and current to the tops.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
