RTA 11TL vs SDA 2B with TL mod
Big Dawg
Big Dawg Posts: 2,005
edited May 2012 in Vintage Speakers
I currently own a pair of SDA 2Bs. I have a line on a pair of RTA 11TLs (what is a fair price?). I'm interested to know how the two compare - what are the similarities and differences in sound (especially if I replace the tweeters in the RTA's with RDO198).
I'm assuming that most here will prefer the SDAs, but I'd like to know if anyone feels differently?
Post edited by Big Dawg on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    The RTA's will work in rooms where SDA's won't. If you don't have at least 14 feet of wall to setup SDA's properly the RTA's will perform better.
    Ben
  • skrol
    skrol Posts: 3,488
    edited January 2010
    The RTA's with the RDO198 and XO upgrade are quite incredible. The sound stage is wider and has a nearly 3D presence without sounding artificial.
    I haven't experienced the SDA's in many years but I'd love to compare.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Big Dawg
    edited January 2010
    ben62670 wrote: »
    I have a large enough space - perhaps too large. The wall that the speakers are on is about 16 feet, and the room is about 23 feet long and mostly open to another room about 18-20 feet more. That's part of why I am wondering. The sweet spot with the 2Bs is fairly small - would the 11TLs open up the listening area? Also, given the similar drivers (and eventually identical tweeters), would they sound about the same (minus the SDA effect)?
  • Big Dawg
    edited January 2010
    skrol wrote: »
    Stan
    I've only heard the SDAs. I've heard good things about the RTAs, though. Are they preferred in the order of size (15TL, 11TL, 8TL)?
    Anyone have thoughts on what is a fair price?
  • domflane
    domflane Posts: 653
    edited January 2010
    Anything around $150 is normal, but I've seen them for closer to $100 in decent shape. I had a chance to get a pair for $120, wish I would have jumped on it.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • ben62670
    edited January 2010
    $200 is fair for minty 11's.
    Ben
    heiney9 Posts: 25,630
    edited January 2010
    I had 11's and have 1C's now. There is no comparison, apples and oranges. The 1C's are "better" in every way. That's not to say the 11's aren't great, but if I had to choose just one pair...............there is no choice SDA 1C's all the way.
    edited January 2010
    I'll add that most SDA's sound very good out of the sweetspot. You don;t the same "effect" but they still sound full and large. You will have the same issue with the 11's. They have a small sweetspot too and off axis they sound very good.
    If you have such a large room try 1C's or 2.3 or 1.2 SDA's if you are having a problem filling the room. The 11's won't put out anymore sound than your 2B's.
    11's are great but SDA's are "better" IMO.
  • Face
    Face Posts: 14,340
    edited January 2010
    If you do the TL mod, you'll forget all about the 11TL's.
  • Big Dawg
    edited January 2010
    Face wrote: »
    My 2Bs already include the TL mod (and sound great). I'm just looking for MORE.
    I guess I'll move on....
    Thanks for the input!
    edited January 2010
    Big Dawg wrote: »
    See post #9 or start improving your gear.
  • kniowsk1
    kniowsk1 Posts: 33
    edited February 2010
    $200 seems like a steal for the 11TLs. If you can find some for that I would jump on it.
  • skrol
    skrol Posts: 3,488
    delete
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skrol
    skrol Posts: 3,488
    kniowsk1 wrote: »
    How much are you paying for yours that you are getting in a couple weeks and that you are so excited about?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    Bigdawg if the 2B's are not giving you what you want in your room you should move up the SDA ladder because the 11TL's are not going to give you anymore than the 2B's infact it could be less. IMHO
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • chumlie
    chumlie Posts: 8,658
    edited May 2012
    bump for ambiophonics.
  • ambiophonics
    ambiophonics Posts: 729
    edited May 2012
    thanks chumlie - exactly the info I was looking for
    2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
  • boston1450
    boston1450 Posts: 7,758
    edited May 2012
    not sure this helps but here goes. i have 16+24 room had sda2b hooked up in that room. sounded awesome. decided to bring them into main room which is much smaller. when i play it now i hear it EVERYWHERE in house. smaller room..i inturn used my RTA15TL's in my bigger room and they sound wonderful. im looking at a pair of 11t's for the big room. hope they are in good condition. should sound good on a HK3470 i have the 2channel hooked to tv on audio as tv is NEVER on anyways. the sda's do very nicely in the room that is 12+14 with openings to other rooms. not sure id wanna use them in a closed small room. probably brain damage for sure. good luck
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
