Lsi setting with SONY 5400es
htrs
htrs Posts: 7
edited January 2010 in Speakers
I am very new at this and after reading reviews and with some inputs from members of Forum have recently bought Lsi9 , lsiC and LC80i (in ceiling) for rear. I have setup everything using HDMI and 16G wires.
I ran the provided stereo mic provided with 5400es and sucessfully setup using automatic speaker setup.
Problem is that i do not feel my rears. I am more of Movie person and have watched couple of movies but I have not fealt my rears kicking IN.
Am I missing anything? I did not had a chance to connect Sub (505) yet.
Thanks in advance.
HTRS
Post edited by htrs on
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2010
    95% of your sound comes from the center channel. You won't hear much from the rears except in very loud action scenes for the most part.
    You can run the test tone and verify they're working and adjust the levels if you want too.
    Main Surround -
  • MANSKITO
    MANSKITO Posts: 295
    edited January 2010
    well you might of (by mistake) incorrectly wired your speakers. Try swapping the wire leads at the receiver end (because you have the in ceiling speakers). If that dose not work try hocking up a known working speaker to the surround out put of the receiver and see if it puts out sound, if not then you know the receiver is broken. Also make sure A/B speaker switching is correctly configured . (that messed me up a lot when I first got started) Lastly your receiver should have a 5 or 7 channel stereo sound mode. Put in a CD and put that mode on sound should be coming out equally from every speaker.
    Monitor 60s, CS10 front
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    Pioneer PD-5010 CD player
    Sennheiser HD 650s :D
    Maverick Audio Tube Magic D1 DAC
    AMD Phenom II 940 @ 3.8 prime stabel
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
    Creative X-fI Titanium Fatal1ty
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    I always run my surrounds hot by about 3db, regardless of how it calibrates.
  • MANSKITO
    MANSKITO Posts: 295
    edited January 2010
    dorokusai wrote: »
    why?
    Monitor 40s, back
    PSW10:(
    H/k AVR 325
    Sansui Tape Deck
    4 gigs 1066, cas 5
    XFX 4890 1gig
    Seagate 1tb 7200.12
  • htrs
    htrs Posts: 7
    edited January 2010
    Guys, thanks for looking into this....I read a lot of reviews before and knew this was a common problem so I was extra careful while putting the wires ... irrespective they are connected by Banana plug and I swaped them at receiver but still no difference.
    I have three settings on LC80i one is wall distance that I have set <2 feet, other are axis and twitter ..I get the axis part but what would tweeter setting do ?
    Dorokusai, you said to keep surround hot by 3DB, how can i change this setting (if you have experience with 5400 menu, which I am sure you would ).
    Other problem could be the placement, the lc80 are in line of my sitting position (my room dimesions contraints) but 12 feet apart, though I can't do much about them now.
  • htrs
    htrs Posts: 7
    edited January 2010
    To clarify, the problem is not in sound output but the quality of sound output (almost NONE) and for movies I have tried higher volumes (-17DB), next would be the music which I rarely play.
  • danger boy
    danger boy Posts: 15,722
    edited January 2010
    try this... is your receiver in Dolby Digital or DTS? be sure the signal you are listening to is one of them. if your receiver is playing a Pro Logic sound. you may not hear much of anything from the rears.
    also, be sure your rears are set to large for a full/large speaker signal.. small will cross it over.
    sounds like it is a set up menu problem in your receiver.. not that it's broken or anything.. just a certain setting might be causing the problem. I know this is a PITA, but can you do a reset on your receiver and delete all setting for set up? that would take everything down to you having to set everything up again, but it may help in the long run to see something that you may have overlooked.
    You also did not mention your source? Are you trying to watch a DVD movie or what? list your source player and how you have it connected to your receiver.
    PolkFest 2012, who's going>?
  • McLoki
    McLoki Posts: 5,231
    edited January 2010
    if you have a 5.1 system (not 7.1) you have your surrounds hooked up to the surround or surround side output on your receiver right? (i.e. - your surround speakers are not hooked up to the "surround - back" outputs on our AVR are they?)
    Michael
    Edit - Depending on your answer above - I may have other questions for you.... (like if 7.1 - are you not getting sound from the surround side, surround back or both channels and what decoding are you doing? (i.e. - pro-logic, dolby digital, DTS, DTS-Master, listening to DVD's, Blu-Rays, or CD's?)
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2010
    Good point Michael, didn't even think of that.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • dorokusai
    edited January 2010
    MANSKITO wrote: »
    why?
    Why not? I like surround effects and enjoy a bit of emphasis on them.
  • kaiserkreb
    kaiserkreb Posts: 16
    edited January 2010
    htrs wrote: »
    Go into the levels menu on your receiver and then just keep scrolling over until you find the subwoofer and bump it up a few notches. I keep mine around +6 and my sub around 30% gain. Seems like a decent level. You can adjust any speaker in the room from this menu as well. If you're using the onscreen GUI, I think it is under settings, speakers, manual. Then you pick the speaker on screen and touch up levels and distances, etc.
    I also have the 5400 and noticed on regular 5.1 decodes, the rear channel is usually flat on auto calibration if you're using Auto A.F.D. You can hit the Movie button right next to A.F.D on the remote and it significantly boosts the surround field in a few predetermined configs. If you don't like the extra noise it provides, (it's hit and miss for me, depending on the movie) you can just leave the receiver set to the Auto A.F.D mode and use the method I mentioned earlier to boost the sub and apply it to your surround rear channels.
    I would also suggest not setting your rears to large and let the sub take care of it at around 80-90 hz but that's just my opinion. I leave all of mine set to small and my velodyne handles the rest. Takes alot of strain off of the amp. Each to their own though. Let your ears guide you.
    Darren
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2010
    Welcome Darren!
    I can adjust all of my speakers volumes through my remote on the fly. Talk about convenient.
  • kaiserkreb
    edited January 2010
    cfrizz wrote: »
    Welcome Darren!
    Well, so can I, just not with a direct function on the remote. All it takes is one menu level and everything is right there. Really don't need to tinker with them much after the initial config anyways so it doesn't really bother me. He wanted help with his 5400ES so I obliged as I also own one.
    tonyb Posts: 33,068
    edited January 2010
    Yeah,chicks and their toys. My avr is bigger than yours...nah nah nah!
    Sorry Cathy, been awhile since I yanked your chain a bit.:p:D
  • cfrizz
    edited January 2010
    tonyb wrote: »
    :eek::D LOL! At least I only brag about my toys once in a blue moon, rather than every other day Tony!:p
  • htrs
    htrs Posts: 7
    edited January 2010
    Guys you all Rock. I learned the Manual setting and changed the rears to +3DB ..that does make a lot of difference, my axis was off by more than 15% so I switch that in LC80i - some improvement. My speakers are all set to small and I tried to change my rear to Large but my 5400 won't allow, though I am happy with what it is now. I have put my crossover at 60 and the combination now sounds like LSi series.
    The provided calibration MIC (though stereo with 5400) is of no use, atleast to my taste and I was better off believing my ears.
    Thanks everyone for their inputs.
    HTRS
    tonyb Posts: 33,068
    edited January 2010
    Maybe I missed something, but I take it your driving all 4 ohm speakers from a receiver ?
  • kaiserkreb
    edited January 2010
    htrs wrote: »
    HTRS
    You should have the ability to set the rears to large, I've never tried to do them seperately from all of the other speakers but I don't see why it would matter.
