Best speaker Wire around $1 per foot
ScudDawg
Hi I was wondering what company out there makes the best speaker wire for around $10 per foot? I have monster Z series I believe with pre terminated banana plugs, and I am debating getting some new wires with shorter lengths possibly, thanks.
Sorry about the mistake in the title, no way to edit it apparently
Home Theater:
Processor: Emotiva UMC-1
Amps: Emotiva XPA-3, Emotiva UPA-5
Center: Polk Audio CSi A6
Fronts: Polk Audio RTi A7
Surrounds: Polk Audio FXI A4
Surround Rears: Polk Audio RTI A3
Subwoofer: SVS 2039 PCi (upgraded woofer)
Power Conditioner: Monster HTS 5100 Signature Series
2 Channel: (work in progress)
Speakers: Polk Audio Monitor 40
Post edited by ScudDawg on
cool will take a look at those, thanksHome Theater:
Speakers: Polk Audio Monitor 40 -
Good ones... I recommend them as well.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
ohhhhh snap....DING DING...
--Gary--
will they outperform the overpriced monster Z1 cables I have? Those 10 gauge wires sound interesting.Home Theater:
On the Canare 4S11 Cable I see it has 4 wires, is that only if I bi wire my speakers say with an AVR and an amplifier? Or is there a way to make it work with just my AVR?Home Theater:
To biwire them you can twist two matching leads together at the AVR end and wire the other end to each set of binding posts.
You could also twist the two matching leads together at both ends and insert them both into a banana plug or spade. This is like having a single larger wire, with the ability to biwire/biamp in the future. I myself would just go for the bluejeanscable 10 ga wire. I had monstercable with a "center core shielding" that was the same diameter as the BJC wire. The BJC not only vastly improved the bass response, but smoothed out the highs and mids as well. The lows no longer roll off as much, the mids seem more crisp....I can't say enough about the stuff. I was not a believer in cables until I started reading on here. The bjc wire will get me through a couple of years until I save up some more money.I gave the MC to my sister because she is just starting out and wanted to improve over the "box cable".Ryan Jozwiak
"Because music was meant to be felt and heard"
polkaudio RTiA9
polkaudio RT35i
polkaudio PSW 404
HK 3370
HK FL8380
HK DVD 22
Adcom GFA 5500
Samsung 40" LCD 120 Hz -
awesome, ty so much for the info, I will go with the 10 gauge and get some banana plugs for them.Home Theater:
I use this BJ Cable and am very happy with it.
BJC Ten White (5T00UP) (White jacket, 10 AWG)
(max. cable length that will fit flat-rate box: 200 feet) 0.99/ft
FYI, it's pretty stiff and somewhat difficult to work with.Things work out best for those who make the best of the way things work out.-John Wooden
