Best speaker Wire around $1 per foot
ScudDawg
ScudDawg Posts: 68
edited January 2010 in Electronics
Hi I was wondering what company out there makes the best speaker wire for around $10 per foot? I have monster Z series I believe with pre terminated banana plugs, and I am debating getting some new wires with shorter lengths possibly, thanks.
Sorry about the mistake in the title, no way to edit it apparently
Home Theater:
Processor: Emotiva UMC-1
Amps: Emotiva XPA-3, Emotiva UPA-5
Center: Polk Audio CSi A6
Fronts: Polk Audio RTi A7
Surrounds: Polk Audio FXI A4
Surround Rears: Polk Audio RTI A3
Subwoofer: SVS 2039 PCi (upgraded woofer)
Power Conditioner: Monster HTS 5100 Signature Series
2 Channel: (work in progress)
Speakers: Polk Audio Monitor 40
Post edited by ScudDawg on
  • Face
    Face Posts: 14,340
    edited January 2010
  • ScudDawg
    ScudDawg Posts: 68
    edited January 2010
    cool will take a look at those, thanks
    Home Theater:
    nooshinjohn Posts: 25,932
    edited January 2010
    Face wrote: »
    Good ones... I recommend them as well.
  • halo71
    halo71 Posts: 4,632
    edited January 2010
    ohhhhh snap....DING DING... :p
    --Gary--
  • ScudDawg
    ScudDawg Posts: 68
    edited January 2010
    will they outperform the overpriced monster Z1 cables I have? Those 10 gauge wires sound interesting.
    Home Theater:
  • ScudDawg
    ScudDawg Posts: 68
    edited January 2010
    On the Canare 4S11 Cable I see it has 4 wires, is that only if I bi wire my speakers say with an AVR and an amplifier? Or is there a way to make it work with just my AVR?
    Home Theater:
  • RyanJoz
    RyanJoz Posts: 116
    edited January 2010
    ScudDawg wrote: »
    To biwire them you can twist two matching leads together at the AVR end and wire the other end to each set of binding posts.
    You could also twist the two matching leads together at both ends and insert them both into a banana plug or spade. This is like having a single larger wire, with the ability to biwire/biamp in the future. I myself would just go for the bluejeanscable 10 ga wire. I had monstercable with a "center core shielding" that was the same diameter as the BJC wire. The BJC not only vastly improved the bass response, but smoothed out the highs and mids as well. The lows no longer roll off as much, the mids seem more crisp....I can't say enough about the stuff. I was not a believer in cables until I started reading on here. The bjc wire will get me through a couple of years until I save up some more money.I gave the MC to my sister because she is just starting out and wanted to improve over the "box cable".
    Ryan Jozwiak
    "Because music was meant to be felt and heard"
    polkaudio RTiA9
    polkaudio RT35i
    polkaudio PSW 404
    HK 3370
    HK FL8380
    HK DVD 22
    Adcom GFA 5500
    Samsung 40" LCD 120 Hz
  • ScudDawg
    ScudDawg Posts: 68
    edited January 2010
    awesome, ty so much for the info, I will go with the 10 gauge and get some banana plugs for them.
    Home Theater:
  • PSOVLSK
    PSOVLSK Posts: 5,390
    edited January 2010
    I use this BJ Cable and am very happy with it.
    BJC Ten White (5T00UP) (White jacket, 10 AWG)
    (max. cable length that will fit flat-rate box: 200 feet) 0.99/ft
    FYI, it's pretty stiff and somewhat difficult to work with.
