switched back to broudband cable.. from DSL
faster100
faster100 Posts: 6,124
I had road runner, switched to DSL for the deal they offered.. stinks.. after 6 months i back on cable modem from bright house, road runner.. the www.bandwidthplace.com stats for my dsl were 648 kbs... now today it says 2.8 -3.3 megabits per sec.. woo hoo it is alot faster to say the least!!!
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by Ryan_Polk on
  • STUFFMD
    STUFFMD Posts: 381
    edited October 2003
    Man I love my Road Runner..yeah it's a little pricy .....had some early modem problems ,but now that's squared away..it rocks reliable.....Faster always go by the motto if it ain't broke don't fix it......
    Stuff
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
  • faster100
    edited October 2003
    Man, i just did a tweak from the above site, and now it shows as 3.4 mega bits.. this thing flies.. im so happy today about this :D
    tired of the slow **** DSL = Damm- slow- lan
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Strong Bad
    Strong Bad Posts: 4,278
    edited October 2003
    My Comcast cable connection showed a 1.7 mps speed. Not too shabby!
    SPEED!!!
    John
    No excuses!
  • Demiurge
    Demiurge Posts: 10,874
    edited October 2003
    3.6 megabits per second
  • faster100
    edited October 2003
    thats what it says http://www.bandwidthplace.com/speedtest/results.html
    2.9 megabits per second
    Run the test again Discuss in the forum
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • ken brydson
    ken brydson Posts: 9,085
    edited October 2003
    I only did 1.2 mbs, still fantastic according to the report. What tweeks did you do? I didn't see anything
  • faster100
    edited October 2003
    Posted: Fri Oct 03, 2003 10:23 am Post subject: Increase your Broadband
    I took this from one UK broadband forum and it works great
    you guys should try
    see you all
    Increase BROADBAND:
    this ones simple:
    this is for broad band connections. I didnt try it on dial up but might work for dial up.
    1.make sure your logged on as actually "Administrator". do not log on with any account that just has administrator privileges.
    2. start - run - type gpedit.msc
    3. expand the "local computer policy" branch
    4. expand the "administrative templates" branch
    5. expand the "network branch"
    6. Highlight the "QoS Packet Scheduler" in left window
    7. in right window double click the "limit reservable bandwidth" setting
    8. on setting tab check the "enabled" item
    9. where it says "Bandwidth limit %" change it to read 0
    reboot if you want to but not necessary on some systems your all done. Effect is immediate on some systems. some need re-boot. I have one machine that needs to reboot first, the others didn't. Don't know why this is.
    This is more of a "counter what XP does" thing. In other words, XP seems to want to reserve 20% of the bandwidth for its self. Even with QoS disabled, even when this item is disabled. So why not use it to your advantage. To demonstrate the problem with this on stand alone machines start up a big download from a server with an FTP client. Try to find a server that doesn't max out your bandwidth. In this case you want a slow to medium speed server to demonstrate this. Let it run for a couple of minutes to get stable. The start up another download from the same server with another instance of your FTP client. You will notice that the available bandwidth is now being fought over and one of the clients download will be very slow or both will slow down when they should both be using the available bandwidth. Using this "tweak" both clients will have a fair share of the bandwidth and will not fight over the bandwidth.
    http://bandwidthplace.com/forum.html
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited October 2003
    Results
    3.4 megabits per second
    Details
    Your raw speed was 3394630.14 bits per second which is the same as:
    Communications
    How communication devices are rated. Kilo means 1,000 and mega means 1,000,000. Examples include 56k modem and 10Mbit Ethernet
    Storage
    414.4 kilobytes per second
    The way data is measured on your hard drive and how file sharing and FTP programs measure transfer speeds. Kilo is 1,024 and mega is 1,048,576.
    1MB file download
    2.5 seconds
    The time it would take you to download a 1 megabyte file at this speed.
    Rating
    Compared to all connection types worldwide, yours is fantastic
    Comparisons
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • STUFFMD
    STUFFMD Posts: 381
    edited October 2003
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    PS2/Gamecube
  • Charles Rose
    Charles Rose Posts: 24
    edited October 2003
    2.4-2.5...Not too bad
  • Polk-a-nizer
    Polk-a-nizer Posts: 225
    edited October 2003
    Hey, You ain't gotta tell me. That office that I post from everynight is a call center where I do tech. support for DSL. IT SUCKS ****! For the $50 they charge; I get NONSTOP calls from cu complaining about all the problems and how it does'nt work right. I know I would'nt get it.;) Stick with cable.
    ††Polk-A-Nizer~~Ulrich††
    Nizer The Wizer
    "I can blast my Polks longer and they keep getting stronger!"
  • rs159
    rs159 Posts: 1,027
    edited October 2003
    The only time my DSL didn't work was a few months ago when the NE had that massive power outage.
    Are you users just stupid? :D
  • rs159
    rs159 Posts: 1,027
    edited October 2003
  • TonyPTX
    TonyPTX Posts: 545
    edited October 2003
    Smokin.....
    Damn....8 lines...I've gotta put my sig on a diet now....
  • polkatese
    polkatese Posts: 6,767
    edited October 2003
    dang, Tony! you have one hell of a connection there....I wouldn't know what I need to do with all those time gain, if I have that speed :cool: cable modem, I take it?
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Strong Bad
    edited October 2003
    What model and brand cable modem are you guys using? That should have a good deal of an effect on speed also. I'm in the 1.5 mps range.
    I'm using the Comcast supplied Scientific Atlanta modem. Always wanted to step up to the Motorola Surfboard, just never took the time.
    John
    No excuses!
  • ken brydson
    edited October 2003
    John
    I've got a Surfboard SB3100 (supplied by Comcast) and I'm only getting 1.2 :confused:
  • faster100
    edited October 2003
    Originally posted by TonyPTX
    Smokin.....
    My highest was 3.4 so im not to far behind, But what do you pay for that 5 megabits?? that is the question... i pay after my 3 months at 21.95, go's to 44.95...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Strong Bad
    edited October 2003
    A friend of mine has Comcast Pro. It's a guaranteed minimum of 3 mps downloads and 375 kps uploads.
    All for the low low price of $90.00 a month. Then again, his company pays for it.
    No excuses!
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited October 2003
    1.3 with no tweaks - I'll try to speed it up.
    SVS
  • TonyPTX
    TonyPTX Posts: 545
    edited October 2003
    OK, the 5.3 Mbps was the work pipe....pretty crappy actually, but hell I'm not managing it nor am I paying for it, the home access is provided by Cox Cable and is generally rock steady at 2.9 Mbps.
    Tony
  • Pauly
    Pauly Posts: 4,519
    edited October 2003
    1.3 non tweaked
    1.3 tweaked
    What gives? Running XP Pro on a compaqnx9010 Laptop. Freaking Verizon DSL. ****! :mad:
    Life without music would
  • faster100
    edited October 2003
    Spastic, I had RR, switched to verizon DSL and it was ok until the last month, then the last 2 weeks it slowed even more.. 659 kbps
    I got Road runner the other day and now im at 3.3 mbps so its smokin faster then DSL.. cable is the way.
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Pauly
    Pauly Posts: 4,519
    edited October 2003
    man i have his DSL for a few months now but latley it seems like it likes to stall breifly. I know its not my computer, so i just might be going cable. DAMN YOU VERIZON!!!!;)
  • faster100
    edited October 2003
    mine was doing the same thing, last 2 weeks worth.. i said eff it.. back to cable. 3.3 megs a sec.......
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • dorokusai
    dorokusai Posts: 25,638
    edited October 2003
    John - We use the same service essentially. If you are capped, you are capped, no amount of tweaks will get you reliable super speed....period. Modem change is not really the answer.
    There a few things you can do, but second stop should be www.dslreports.com , they have a large active forum for users of all connections. Check it out and gain some speed, but don't expect milestones.
    Comcast caps in our area, its a fact, and it sucks.
    P.S. I run reliable at 1.7/240 and that is fine by me.
  • Frank Z
    Frank Z Posts: 5,860
    edited October 2003
    GAWD Damn....What bunch of cheese eatin wieners!! I'm stuck with a freakin 56k modem that gets up to 48000 when everyone else in town is asleep! Be thankful for what you got...ya high speed bastages!! Do you have any idea about how long it takes to download a **** 10 second **** clip at 48kbs...DO YA?!?:mad:
    (leaves the room muttering "Effin Phone Company")
  • faster100
    edited October 2003
    :D
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
