what is a compatible
tyheeguy
so here's what i have....rti a9's for fronts..a csi a6 for a center and rti a3's for my rears. using a sony str da5400es AVR. planning on rti a5's for my side/surrounds and a dsw pro 600 as a sub. the room is 12'6" wide X 15' long. do i need a amp, how many channel should i get and what brand would be compatible?????.....new to this game and i really don't have a clue what i am doing....hoping for some input from all that have thoughts
Be good.....and if you can't be good, be great.........and if you can't be great, well,......i'll give you lessons.
Post edited by tyheeguy on
What you have now will provide hours of pleasure from your HT. If you are using a regular DVD player I would get a Bluray player before I even started thinking of an amp.
If you have a BR, and are using the new sound formats, then what an external amp brings to the game is, generally speaking, more, and cleaner, power which usually results in a better, more detailed sound. Personally, I would stick with 5 channel versus 7 at this time. Equipment costs less, you need two less speakers, and you probably experience 99.9% of the surround sound effects.
Of course, if you like the amp then you will start thinking of speaker upgrades, better inter-connects, and better speaker wire. It is a never ending process.Lumin X1 file player, Westminster Labs interconnect cable
