Fragnstein controller for PS3
Jetmaker737
Anybody use one of these? I ordered one up.
http://www.bannco.com/index.php?option=com_content&view=article&id=58&Itemid=18
I just got a PS3 and I'm just not good with console controllers. I played FPS's on the PC for years with mouse and keyboard. Hopefully this will fix me up.
Post edited by Jetmaker737 on
If you're supposed to use that mouse and handheld Wii style controller at the same time....it seems lame. I want both hands on one controller when playing games unless it's motion capture like the Wii (and Natal)
we'll see... like I said, I'm used to mouse and keyboard so the mouse part will be cool for me. It's just a matter of learning the nunchuk thing.
I have problems trying to control the little tiny thumb joystick for precision looking and aiming on the regular controller.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
I'm used to a mouse and keyboard (Nostromo N52te Speed Pad, to be precise) when I'm playing a computer game, but on a console just having a controller in one hand with a joystick to manage aim and a mouse seems incredibly more difficult to me.
Let us know how it works. Just about anything may be an upgrade to the PS3 controller.
I don't own one, but I've heard they aren't very good. I'm really interested in hearing your opinion on it. Be sure to let us know how it is.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
It's being shipped now. I'll report back in a week or so after using it a bit.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub
Jetmaker - how'd it turn out? You like it? Recommend it?My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
I've had it now for a couple of weeks which for me is only a few hours playing time.
Set-up is a bit of a hassle due to there being three different sensitivity settings. And sensitivity is key to get a good compromise between speed in-game versus micro-movement accuracy. You need to be patient with this aspect. At this point though I have it set up pretty well. The mouse isn't as accurate in micro-movement as on a PC, but pretty close. Plus the PS3 seems to be a little more forgiving with your aim than, say, CS was. So I'm getting pretty good results on the campaign. I have yet to play online.
The utility lets you re-map keys however you want, which is sweet. I've experimented with a few configs and I'm getting it dialed in pretty well.
The FnS controller parts are well made and feel durable. There seems to be good support on their website with firmware updates posted occasionally. I'm using a huge mousepad (about 18"x12") set on a cutting board. It's very easy to play with this on my lap or sitting in front of me.
The FnS may not be for you if you're good with the PS3 controller. But if you've been raised on PC games with mouse and keyboard it's a decent way to get you in on PS3 gaming. Of course YMMV!
Jet :cool:SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|REL T/9X SE Sub -
Good write up man, I myself don't like the new Dualshock 3 controllers. Too heavy and I personally hate the vibration function, I know you can disable it, but still too heavy. I love my Sixaxis that came with my PS3, but they are no longer being made/sold at retailers. Can probably get them online still, so I will have to get a couple before they dissapear for good.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Off topic but have to ask while some PS3 folks are looking.
Will any Bluetooth keyboard/mouse combination work with a PS3? or do I have no choice but the one Sony offers?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Mark, most V1.1, 1.2 and 2.0 Bluetooth devices will work. I personally have used Jabra and Plantronics (currently) and have had no issues. Did a Google search on a list of compatiable devices and I will post the results. It's the first one, but it is firewalled here at work, so click that first one and see what it says. IMHO any of those three version devices should work, YMMV.
-Jeff
http://www.google.com/search?hl=en&safe=active&q=ps3+bluetooth+keyboard+compatibility&aq=f&aql=&aqi=&oq=HT Rig
Blu-Ray- 80 GB PS3
I just need to use an actual mouse over a touch pad. I'm simply not coordinated enough to use a controller sometimes.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
