RTi A3 or FXi A6?
cbruinooge
cbruinooge Posts: 11
Just wondering which would go better with my RTi A9's, and CSi A6?
Post edited by cbruinooge on
  • danz1906
    danz1906 Posts: 5,144
    edited December 2009
    RTiA3s in the rear..........FxiA6 on the sides.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • danz1906
    Welcome to the Club!
    Both speakers will go well with the A9s and A6 center.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
  • leroyjr1
    leroyjr1 Posts: 8,785
    It all depends on your room size and configuration. For me 4 fxi a6's worked best as surrounds.
  • tyheeguy
    tyheeguy Posts: 14
    .........what about a5's for the sides and a3's for the rear??????
    Be good.....and if you can't be good, be great.........and if you can't be great, well,......i'll give you lessons.
  • superjunior
    superjunior Posts: 1,632
    that really depends on your room configuration. each speaker has its advantages. consider the space and proper placement needed for the a5s, the versatility with the fxis, the small size and big sound from the a3s, they're all great speakers just depends on what will work best for your room
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • cbruinooge
    I'm thinking it will be a 5.1 for now. I am living in an mid/large apartment right now but, am buying a house soon. Don't know what size room this will all go in yet but it should be good sized. The room that is is in right now is about 20by 15 with a 6 by 8 foot opening to another room the same size. I really want the A5's the most but the A3's are more in my price range. I could always get the A3's now for rears and then when I go 7.1 just use them for side's and buy the A5's for rears. What do ya think about that?
  • leroyjr1
    cbruinooge wrote: »
    That'll work. Get what works now and get the a5's later if needed.
  • gp4jesus
    gp4jesus Posts: 2,019
    edited January 2010
    You may find placing A1s or A3s easier as side/rears than a floorstanders. BTW the way I'm a big fan of the RTi A series speakers
    *all connected w/Premiere ICs
  • domflane
    domflane Posts: 653
    edited January 2010
    I'm also looking to upgrade the rears in my 5.1. For me, its a choice between the A3's and the FXi. I'm really leaning towards the A3's for their versitility. They are really nice bookshelves and can be used in a lot of applications.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • madnod
    madnod Posts: 79
    edited January 2010
    cbruinooge wrote: »
    i personally went with the FXI A4 for side surrounds, RTI A1 for rear, front sound stage is RTI A9s and CSi A6, room is 18.5X 28 seating is in the middle,
    excellent setup,
    i chose the A4 and A1 since their driver matches the A9s.
    my sub is the DSW pro 600
